hawkati Posted February 1 Report Share Posted February 1 ...but not for long. It'll get some ex race panelling and be transmogrified into a ldu tart. Yip. It's that notorious R1 that's obviously far too good for ldu except It's a rusted up fukker of an electrical nightmare. Doesn't stop everyone else having a pop though😂 Anyway, I'm shifting this to LDC24 where it rightly belongs. So, to recap, I bought an R1 that hadn't turned a wheel since 2009. The usual way of things = bung a new battery on, fresh fuel and ride off into the sunset. Nope, not this one - best part of a month chewing my way through the loom and replacing relays & switches as we go. Don't look too close. Until today. I'd got it going by shorting the solenoid but there were no lights, the forks are slightly askew and there's stiction. Other than that it's got potential, so onwards to the next stage. Common denominator for lights and starter is the right hand switchgear and connectors so they got drowned in contact cleaner. Nada. ripping airbox and ignition coils off, I could get a proper go at the wiring....and as I flexed it the lights would flicker on & off. Checked again and it looks like it got routed awry and pinched. So, offski it comes ready for a proper good old check. I'm going in and I may be some time. 2 1 Quote Link to comment Share on other sites More sharing options...
srad34 Posted February 1 Report Share Posted February 1 James, you have stripped and checked the main white block connector too right? 1 Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 1 Author Report Share Posted February 1 1 hour ago, srad34 said: James, you have stripped and checked the main white block connector too right? Very much that. Yup, done that three times!😂 It does seem to relate to the wiring connected to the right hand switchgear - all the lights, starter and the front brake light wires go awol when I wiggle the wires. Not good, so that's getting checked for breaks once I've dissolved the vile glue gunk from the stupid insulation tape wrapped around the wire casing. Yuk. Quote Link to comment Share on other sites More sharing options...
srad34 Posted February 1 Report Share Posted February 1 34 minutes ago, hawkati said: Very much that. Yup, done that three times!😂 It does seem to relate to the wiring connected to the right hand switchgear - all the lights, starter and the front brake light wires go awol when I wiggle the wires. Not good, so that's getting checked for breaks once I've dissolved the vile glue gunk from the stupid insulation tape wrapped around the wire casing. Yuk. For the relative cheap cost of a replacement, Shirley this is a better option? Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 1 Author Report Share Posted February 1 49 minutes ago, srad34 said: For the relative cheap cost of a replacement, Shirley this is a better option? You're quite right, but stop calling me Shirley! I'm already getting a fair amount of pisstaking from the dullsville brigade about my posh expensive bike😂😂😂 Quote Link to comment Share on other sites More sharing options...
jollygiant Posted February 1 Report Share Posted February 1 (edited) 3 hours ago, hawkati said: ...but not for long. It'll get some ex race panelling and be transmogrified into a ldu tart. Yip. It's that notorious R1 that's obviously far too good for ldu except It's a rusted up fukker of an electrical nightmare. Doesn't stop everyone else having a pop though😂 Anyway, I'm shifting this That green can near the door, plonk it straight across the battery terminals and exit though that door rapidly, then close it and all the problems will be solved. No charge for this advice. Edited February 1 by jollygiant 1 Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 1 Author Report Share Posted February 1 1 hour ago, jollygiant said: That green can near the door, plonk it straight across the battery terminals and exit though that door rapidly, then close it and all the problems will be solved. No charge for this advice. But that's super unleaded - worth more than the bike! 1 Quote Link to comment Share on other sites More sharing options...
jollygiant Posted February 2 Report Share Posted February 2 10 hours ago, hawkati said: But that's super unleaded - worth more than the bike! Super How the other half live. I have to run mine on meths or special brew. 1 Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 2 Author Report Share Posted February 2 2 hours ago, jollygiant said: Super How the other half live. I have to run mine on meths or special brew. Just trying to save the tank from the ravages of wintery ethanol aided rust. Not like I'm clocking up the mileage on this😂 1 Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 5 Author Report Share Posted February 5 No fucking work today so after a mum visit it's time to crack on with stuff. ...and I find the r1 is possessed by the spirit of gixxxrrrr. Fack Worse still, the 2009 tyres are welded to the wheels. I have to break the beading, literally, to get it off. Double fack. I throw comedy wheel on thd bike because the stable floor is too....unstable for a paddock stand. Ersatz duvet spray booth rigged in living room and I crack on with it. I am now completely off my tits on fumes. 1 6 Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 8 Author Report Share Posted February 8 Shitty rainy arse of a day so time to wield hammers. Yup, that's the rear wheel back on with luvverly rubber, though I've not replaced chain & sprockets yet. Reason being an adjustor, like so many other bolts, is seized solid. Much plusgas and I'll attack it again soon. Meanwhile, off with the front wheel overcoming yet another buggery bolt of seizure. Proper hammer & impact driver time. All but one bolt = 5 minutes. One bolt = an hour, ffs. Said it before, who needs gyms when there are cunty old tyres glued to wheels? Finally... ...and the living room risks spontaneous combustion once again On the plus side it'll take a couple of bolts to replace the silencer, and there's nowt wrong with the rear shock so the one that got sold with the bike gets bunged on't bay. 9 Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 13 Author Report Share Posted February 13 Wheels repainted and roadtecs on, now back to the big issue...its electronic cuntiness. R/h switchgear completely checked, lubed, whispered sweet nothings, the works. Got headlights & sidelights going = goody! Baddy = no front brake lever lights and still no starter on the button. Replaced starter solenoid = nope, still not on the button, but can fire up for 5 whole seconds with pliers before it cuts out regardless of choke or throttle position. Replaced starter assembly relay block - still no button start but will run all day long with pliers assist. Until it chose to die and not start again. I say fack several dozen times then close stable door on it, the cunty thing. 3 Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 13 Author Report Share Posted February 13 Now the fuel tap has pissage issues too. Fixing kit ordered. 1 Quote Link to comment Share on other sites More sharing options...
Thunderbolt Posted February 14 Report Share Posted February 14 @hawkatiTyre Messiah, is this a 4XV? Quote Link to comment Share on other sites More sharing options...
trackdaybob Posted February 14 Report Share Posted February 14 38 minutes ago, Thunderbolt said: @hawkatiTyre Messiah, is this a 4XV? It's a 5JJ. Rear lights give it away amongst other things 1 Quote Link to comment Share on other sites More sharing options...
Thunderbolt Posted February 14 Report Share Posted February 14 1 hour ago, trackdaybob said: It's a 5JJ. Rear lights give it away amongst other things Anorak 1 4 Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 14 Author Report Share Posted February 14 Indeed - 2nd gen. Arguably betterer so holds less value than the first gen. Like my 996 compared to the brittle 916. Suits me sir. 1 Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 19 Author Report Share Posted February 19 A dry couple of hours and had another go at the bastard. It's acting like the battery is gutless and dead despite it being brand new, and to compound my misery bith my multimeters are.....somewhere! Bike being charged now and offski to go visit mum and probably buy another multimeter. Fack. Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 19 Author Report Share Posted February 19 Battery charging = turns over on the button but struggles to fire up. Ripping apart the fuel tap to replace seals (arp) reveals reason why. Sad fuel tap is sad Not surprising Can you guess I'm being a forum tart yet? 8 Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 19 Author Report Share Posted February 19 Meanwhile it's cold in the shire so indoors for some fairing fettling. Got these mid panels for an extortionate £2.95 each. Mainly because of the crap paintwork- flames or dildos, you choose. The original fairings are far too nice for what I'm planning, to turn this into a painted and bestickered cancer research tart so these are ideal. 4 Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 21 Author Report Share Posted February 21 here goes - let's see if this breaks... https://fundraise.cancerresearchuk.org/page/james-serjeant-2024 1 Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 21 Author Report Share Posted February 21 Cunty work is cunty. Three line whip meant Monday Tuesday and Thursday off work turned into no days off at all this week so not had much chance to do anything to bike but it's getting charged like a rabid rhinoceros ready for a weekend onslaught. It's good not having litres of fuel missing on the stable floor as well ... Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 22 Author Report Share Posted February 22 Something I did earlier. Hoping to do a bunch of 2 minute vids showing the rebuild and aiming to have a bike & helmet cam to record the ride - I so need to learn video editing skills... 8 Quote Link to comment Share on other sites More sharing options...
cuban pete Posted February 22 Report Share Posted February 22 17 minutes ago, hawkati said: Something I did earlier. Hoping to do a bunch of 2 minute vids showing the rebuild and aiming to have a bike & helmet cam to record the ride - I so need to learn video editing skills... That's such a lovely looking thing. Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 22 Author Report Share Posted February 22 1 hour ago, cuban pete said: That's such a lovely looking thing. honestly, the fairing, seat unit and tank all look really good. Underneath it's more or less rotten to the core. There's going to be a hell of a lot of tlc and time spent on this thing. Quote Link to comment Share on other sites More sharing options...
cuban pete Posted February 22 Report Share Posted February 22 32 minutes ago, hawkati said: honestly, the fairing, seat unit and tank all look really good. Underneath it's more or less rotten to the core. There's going to be a hell of a lot of tlc and time spent on this thing. Will be worth it in the end 😁 1 Quote Link to comment Share on other sites More sharing options...
hawkati Posted February 22 Author Report Share Posted February 22 28 minutes ago, cuban pete said: Will be worth it in the end 😁 Yes - daren't spend any more until after the ldu or the ridicule will be ludicrous, but then i'll aim to make it a quality trailer princess Quote Link to comment Share on other sites More sharing options...
oggy411 Posted February 23 Report Share Posted February 23 Never owned an R1. I’m finding that it’s an itch I need to scratch and vids like this aren’t helping. 2 Quote Link to comment Share on other sites More sharing options...
fastfreddybikes2 Posted February 23 Report Share Posted February 23 5 minutes ago, oggy411 said: Never owned an R1. I’m finding that it’s an itch I need to scratch and vids like this aren’t helping. 5JJ model are really good and for the money just outstanding value. Great motor surprisingly comfy stunning brakes (sbs pads). Go like stink very stable good handling things. Brilliant on track from oulton big balls speed to nadgery old Cadwell. Long distance road munching is no problem and even pillions didn’t complain overly. Have you bought one yet? 3 Quote Link to comment Share on other sites More sharing options...
oggy411 Posted February 23 Report Share Posted February 23 44 minutes ago, fastfreddybikes2 said: 5JJ model are really good and for the money just outstanding value. Great motor surprisingly comfy stunning brakes (sbs pads). Go like stink very stable good handling things. Brilliant on track from oulton big balls speed to nadgery old Cadwell. Long distance road munching is no problem and even pillions didn’t complain overly. Have you bought one yet? I’m looking for a near minter. I can probably afford a later one (crossplane) but I’d rather have a stunning earlier model than a later one needing work at the same money. What are the issues to look for? Quote Link to comment Share on other sites More sharing options...
