Gobert Posted May 8, 2020 Report Share Posted May 8, 2020 3 minutes ago, Damnthistinleg said: Which is correct but I think we're discussing slightly different things. I think we are - the OP said he only had 20mm static sag which is a lot less than whats generally regarded as the default road setting on a sportsbike - 30mm. I can't think of anything easier than reducing the preload to give that amount and riding the bike to see if it improves things. Once he's tried that he can start looking at loaded sags, changing springs if necessary and fine tuning the bike to suit him. Quote Link to comment Share on other sites More sharing options...
David W Posted May 8, 2020 Report Share Posted May 8, 2020 (edited) 2 hours ago, CRM said: My 45 the settings are There is 15mm sticking out the top of the yokes the top screw brass thing is 5 clicks back (it was 4 but there was another click once you worked it a couple of times) the bottom screw brass thing is also 5 clicks back there are 4 rungs showing on the preload adjusters on the forks (22 mm nut) Now according this this the 45 should only have Is that how they leave the factory and have you got it set like that now? I’m quite surprised that standard factory settings show that the standard kit is almost out of rebound adjustment! How many clicks of adjustment is available? Edited May 8, 2020 by David W Quote Link to comment Share on other sites More sharing options...
CRM Posted May 8, 2020 Author Report Share Posted May 8, 2020 3 hours ago, David W said: Is that how they leave the factory and have you got it set like that now? I’m quite surprised that standard factory settings show that the standard kit is almost out of rebound adjustment! How many clicks of adjustment is available? there are about 15 clicks top and bottom and around 15 turns of the preload adjusters Quote Link to comment Share on other sites More sharing options...
CRM Posted June 18, 2020 Author Report Share Posted June 18, 2020 Right - bit of an update from the nice gents at Maxton. RC30#1 Rear shock As expected way too softly sprung and had also lost some gas in 13 or so years. Shock been resprung to suit my weight, and rebuilt using new seals and ride height set correctly, Apparently there was something like 3 x too much static sag hence why it felt like a dog draqgging its arse and flip flopping into corners from the front. Now has less sag and ride height set to racing measurements (more up to date than the standard setting) and catering for the 17" rear wheel. Front forks Serviced and refreshed. There was some note about the airgap being much less than it should be resulting in less travel. turns out the forks show minor pitting at the very top so he thinks this has been done to stop the fork travelling into that area of the fork which is fine for road and light track use. So these have been put back as they were with fresh fluid and seals and optimised for the travel area. I always felt the front forks were just about right and the draggy front end was more because of the rear squat. The bike feels taller now and more poised to sit on. god i love this bike just putting it back together today, what a bike to work on, everything about them is just so nice. I will report back after its first test ride and outing. 3 Quote Link to comment Share on other sites More sharing options...
bogman Posted June 18, 2020 Report Share Posted June 18, 2020 (edited) What do they charge for a fork service as described? Edited June 18, 2020 by bogman Quote Link to comment Share on other sites More sharing options...
CRM Posted June 18, 2020 Author Report Share Posted June 18, 2020 2 minutes ago, bogman said: What do they charge for a fork service as described? that lot was £430 all told for the shock and forks. Quote Link to comment Share on other sites More sharing options...
bogman Posted June 18, 2020 Report Share Posted June 18, 2020 Reasonable Quote Link to comment Share on other sites More sharing options...
