southwestbiker Posted July 16, 2009 Report Posted July 16, 2009 Hi, dont know if anyone is up on the wiring on the clocks on a GSXR K1, but i could do with bit of help indentifying the right wire. The bike I have at the mo is a 96 GSXR 750, and the previous owner has fitted a set of K1 clocks. As he only used it for a trackbike, he has only wired up the rev counter. However, im using it on the road, and i have decided that its time to get the speedo working. I can see the wires coming out of the sprocket cover whcih i assume are the speedo sensor. Any idea which wires i should mate this up with on the clocks? Any help would be appreciated, im getting fed up of trying to keep to unrestricted roads and bypassing cameras! Cheers!
southwestbiker Posted July 16, 2009 Author Report Posted July 16, 2009 Nice one, cheers mate, just tracked it down over there, hes doing a kit for £12 Good times!
originalracingsnake Posted July 17, 2009 Report Posted July 17, 2009 www.oldskoolsuzuki.org are you friends for this sort of thing too.
