heds954 Posted July 15, 2009 Report Share Posted July 15, 2009 The ones I presently have in 'Project Moneypit' are mullered, as the title says which is better? Ta Heds Link to comment Share on other sites More sharing options...
MonkeyJim Posted July 15, 2009 Report Share Posted July 15, 2009 in my experience, I've always found the OE ones are the best, whatever they are. pattern copies may be a bit cheaper, but I'd plump for the proper ones every time. Link to comment Share on other sites More sharing options...
Gray01 Posted July 15, 2009 Report Share Posted July 15, 2009 My guess would be copper. Based on no experiance or facts whatsoever Either would be better than none though. HTH G Link to comment Share on other sites More sharing options...
gurninman Posted July 15, 2009 Report Share Posted July 15, 2009 My guess would be copper. Based on no experiance or facts whatsoever Either would be better than none though. HTH G IME, makes fuck all difference which you use - I've used both with no problems. Link to comment Share on other sites More sharing options...
heds954 Posted July 15, 2009 Author Report Share Posted July 15, 2009 IME, makes fuck all difference which you use - I've used both with no problems. Hmm, didn't think it did, they're pretty much the same price wise, just seems to be a slight preference between one and the other when Googling. Meh, the worse that can happen is I have to spend another £6, not the end of the world. Link to comment Share on other sites More sharing options...
will#224 Posted July 15, 2009 Report Share Posted July 15, 2009 I'd guess copper on an older bike. More likely to damage manifold studs trying to compress the ally than the softer copper Anyone care to disagree? Link to comment Share on other sites More sharing options...
gurninman Posted July 15, 2009 Report Share Posted July 15, 2009 Me! me! I don't think you need extra torque to seal with aluminium gaskets - they are more of a concertina section, so should seal equally well for the same torque. Of course, I could well be talking bollocks in which case I'll poke my own arse with the rough end of a ragman's trumpet. Link to comment Share on other sites More sharing options...
Gobert23 Posted July 15, 2009 Report Share Posted July 15, 2009 Either would be better than none though. HTH G ...or trying to make exhaust gaskets from a corn flakes packet... Mmm, crispy... (I've seen head gaskets fashioned from breakfast cereal packets though ) Link to comment Share on other sites More sharing options...
