charlie R Posted July 8, 2009 Report Share Posted July 8, 2009 Can anyone help, I've got a chance to buy a set off light road/race wheels for my GSXR1000 but they are K3/4 and mine is a K1. Is there any way to get them to fit a K1 or not??. Would I have to change the forks and/or swing arm??. Any advice will be greatly appreciated, cheers Charlie. Link to comment Share on other sites More sharing options...
charlie R Posted July 8, 2009 Author Report Share Posted July 8, 2009 01-04 1000 front wheels are the same- straight swaps. You will need to change the brake discs K1 1000s had 320mm discs on the front, K3/4 had 300mm discs. Rear discs on K1 are 240mm, K3/4 are 220mm. Dunno about rear spacers/sproket etc though. Details for compatibility here: cheers for the info sounds like it may well be worth the chance and get some spacer made up for the back, once again thats. Link to comment Share on other sites More sharing options...
2 smokes 4 ever Posted July 9, 2009 Report Share Posted July 9, 2009 Indeed thay are the same wheels and should drop striaght in Rear shouldn't even need a different spacer SV1000 uses same fornt wheel and any forks from 1K 01-04 & 600/750 01 -05 fit with the std suzuki wheel Link to comment Share on other sites More sharing options...
charlie R Posted July 9, 2009 Author Report Share Posted July 9, 2009 Indeed thay are the same wheels and should drop striaght in Rear shouldn't even need a different spacer SV1000 uses same fornt wheel and any forks from 1K 01-04 & 600/750 01 -05 fit with the std suzuki wheel Cheers, do you happen to know if the wheel spindles are the same and bearing size etc ??? Link to comment Share on other sites More sharing options...
