riversbikes Posted April 24 Report Share Posted April 24 Hey all -- wiring question. I have a typical three-wire headlight harness on my ducati -- ground, high and low beam. I want to replace the headlight with a 90mm hella light (for a neat endurance look), which has a high and low beam via a shutter, vs. separate bulbs or dual filament bulbs. So each function only has 2 wires -- a ground and a positive feed. Will the attached schematic work in theory? Split the ground wire to both the bulb (upper) and the shutter pigtail, with the low beam positive going to the shutter (to switch it as necessary), and the high beam positive going to the bulb? The xenon bulbs/headlights like this require ballasts, but not the halogen one. 1 Quote Link to comment Share on other sites More sharing options...
TLRS Posted Tuesday at 01:48 AM Report Share Posted Tuesday at 01:48 AM On 4/24/2024 at 3:07 AM, riversbikes said: Hey all -- wiring question. I have a typical three-wire headlight harness on my ducati -- ground, high and low beam. I want to replace the headlight with a 90mm hella light (for a neat endurance look), which has a high and low beam via a shutter, vs. separate bulbs or dual filament bulbs. So each function only has 2 wires -- a ground and a positive feed. Will the attached schematic work in theory? Split the ground wire to both the bulb (upper) and the shutter pigtail, with the low beam positive going to the shutter (to switch it as necessary), and the high beam positive going to the bulb? The xenon bulbs/headlights like this require ballasts, but not the halogen one. I'm no sparky by any means.. but that makes sense. Should be easy to bench test? Quote Link to comment Share on other sites More sharing options...
riversbikes Posted Tuesday at 02:40 AM Author Report Share Posted Tuesday at 02:40 AM 50 minutes ago, TLRS said: I'm no sparky by any means.. but that makes sense. Should be easy to bench test? Yup, as soon as it shows up in the mail I'll see if I can get it to work. I might wire the low positive feed to the bulb, and have the high beam work the shutter. Might need a diode in line as well -- I could see the shutter activation (high beam), turn the low beam (bulb) off... Quote Link to comment Share on other sites More sharing options...
