Evilchicken0 Posted July 2, 2022 Report Share Posted July 2, 2022 I think this is a thing, it doesnt expand when it heats up either What's the product name do we really like it, is it, is it wicked ??? 1 Quote Link to comment Share on other sites More sharing options...
fastfreddybikes Posted July 2, 2022 Report Share Posted July 2, 2022 9 minutes ago, Evilchicken0 said: I think this is a thing, it doesnt expand when it heats up either What's the product name do we really like it, is it, is it wicked ??? We are loving it like that… Quote Link to comment Share on other sites More sharing options...
Superdunc Posted July 2, 2022 Report Share Posted July 2, 2022 Evan's waterless coolant. Horrible stuff. Like filling you cooling system with brake fluid. Yuck. 3 1 Quote Link to comment Share on other sites More sharing options...
426hemi Posted July 2, 2022 Report Share Posted July 2, 2022 You might as well use neat antifreeze as evans. Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 2, 2022 Author Report Share Posted July 2, 2022 Hmmm - how many for then Quote Link to comment Share on other sites More sharing options...
Gixxerthou Posted July 18, 2022 Report Share Posted July 18, 2022 I think you may mean this Boris: https://www.redlineoil.com/waterwetter I was going to use it in my Car a while ago, but changed my mind in the end. We call it WetterWatter round my way. 1 1 Quote Link to comment Share on other sites More sharing options...
Gammaboy Posted July 25, 2022 Report Share Posted July 25, 2022 On 7/19/2022 at 2:58 AM, Gixxerthou said: I think you may mean this Boris: https://www.redlineoil.com/waterwetter I was going to use it in my Car a while ago, but changed my mind in the end. We call it WetterWatter round my way. Water wetter and waterless are two different things. Water wetter acts as a detergent to reduce the surface energy of the coolant and improve wetting of the cooling system surfaces, which can improve the heat transfer through the cooling system. Waterless is a coolant substitute that promises reduced coolant temps and no boiling due to its high boiling point. What they don't mention is that the reduced coolant temps are due to shitty heat transfer, with associated increase in cylinder head temps... 2 2 Quote Link to comment Share on other sites More sharing options...
2639 Posted July 28, 2022 Report Share Posted July 28, 2022 I understand some of the higher performance coolants are flammable. Not an issue on it's own, theres plenty of potential fuel when you look. But few would immediately expect leaking coolant to be the source of a fire. Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 30, 2022 Author Report Share Posted July 30, 2022 On 7/26/2022 at 12:48 AM, Gammaboy said: Waterless is a coolant substitute that promises reduced coolant temps and no boiling due to its high boiling point. What they don't mention is that the reduced coolant temps are due to shitty heat transfer, with associated increase in cylinder head temps... That's the kind of thing I need to know Quote Link to comment Share on other sites More sharing options...
Gammaboy Posted July 30, 2022 Report Share Posted July 30, 2022 7 hours ago, Evilchicken0 said: That's the kind of thing I need to know I feel like it's what everyone needs to know about that stuff! The one upside is it apparently doesn't lead to corrosion of high mag castings, so might be the answer for things like NSR500 twins. 1 Quote Link to comment Share on other sites More sharing options...
Jenny Pryde Posted July 30, 2022 Report Share Posted July 30, 2022 40 minutes ago, Gammaboy said: I feel like it's what everyone needs to know about that stuff! The one upside is it apparently doesn't lead to corrosion of high mag castings, so might be the answer for things like NSR500 twins. Boy, I wish I had that problem! Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted August 1, 2022 Author Report Share Posted August 1, 2022 I wondered about it because the coolant is discoloured, a brown / rust and I thought if there wasnt any expansion i wouldnt need an expansion bottle Quote Link to comment Share on other sites More sharing options...
Gammaboy Posted August 1, 2022 Report Share Posted August 1, 2022 There's still expansion. 1 Quote Link to comment Share on other sites More sharing options...
