Pinkbike1 Posted June 3, 2021 Report Share Posted June 3, 2021 (edited) So I've found a can of pre mix in the shed from when I was trialling! Can't remember the ratio but it's Shell V power with Putoline strawberry two stroke . So the question is , the only petrol driven vehicle I have is the Sprint or the 600RR track bike, if i was to put no more than 1/2 litre per tankful to use it up would it cause any problems? @Sideshow Pob @Superdunc @Mark/Foggy Edited June 3, 2021 by Pinkbike1 Quote Link to comment Share on other sites More sharing options...
bignige Posted June 3, 2021 Report Share Posted June 3, 2021 Better off in the car as long as it's not diesel. 🙂 1 Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted June 3, 2021 Report Share Posted June 3, 2021 Put 1/2 lt in a friends bike and see what happens. Chucking all of it into a diesel car is probably the answer. Is not going to do any harm to Dr Diesel. 1 Quote Link to comment Share on other sites More sharing options...
Sideshow Pob Posted June 3, 2021 Report Share Posted June 3, 2021 You’ll be black flagged on track and the rossers will be able to follow the smoke trail for miles on the road. Time to buy another bike then! Quote Link to comment Share on other sites More sharing options...
coombehouse Posted June 3, 2021 Report Share Posted June 3, 2021 Buy a chainsaw Quote Link to comment Share on other sites More sharing options...
jim157 Posted June 4, 2021 Report Share Posted June 4, 2021 530D or CR500 would be the answer to your quandary. Quote Link to comment Share on other sites More sharing options...
jollygiant Posted June 4, 2021 Report Share Posted June 4, 2021 4 hours ago, Tony Nitrous said: Buy a petrol engines drill ! (can you tell I haven’t given up on this yet?) 32 minutes ago, jim157 said: CR500 would be the answer to your quandary. Go on you know you want too*!! * Please live stream your first attempt at using it here! 1 Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted June 4, 2021 Report Share Posted June 4, 2021 Grab yourself a big Mag Drill with a tired motor and I can see it working well. Bit of throttle control would be much better than an on off switch for cutting well with a 2" hole saw in 50mm plate. Sounds like you might be heading for a Tractor shaped retirement from fast bikes fettling though..... If it's the menopause, talk to someone....They have patches. 1 Quote Link to comment Share on other sites More sharing options...
Mohawk Posted June 11, 2021 Report Share Posted June 11, 2021 (edited) Back in the very very dark & distant past I put two stroke petrol mix in my C90 by accident, well I stole it from my dads can not realising it was for the mower. Anyway bike conked out on it. Being very poor I stripped plug out & cleaned it. Drained the tank & ran the fuel through a load of kitchen towel as a filter. Put it back in & it ran fine. You could try same with some new fuel for good measure. Edited June 11, 2021 by Mohawk Quote Link to comment Share on other sites More sharing options...
