rusty Posted June 3, 2021 Report Share Posted June 3, 2021 I've just used the last of a can of Wurth Dry Chain Lube on the bike so before I buy another tin, is there anything better that's worth getting instead? Quote Link to comment Share on other sites More sharing options...
GSXR814 Posted June 3, 2021 Report Share Posted June 3, 2021 Not that ive found. I usually use the same stuff as you. Quote Link to comment Share on other sites More sharing options...
nampus Posted June 3, 2021 Report Share Posted June 3, 2021 I'm on my first can of S100 dry lube, always used regular chain lube before. Is it a dry lube thing that the rollers on the chain are shiny within about 300km's/180miles? Often sooner. I always used shiny rollers as an indicator that the chain needs lubing. And it seems the dry lube does not last very long. No more crap on the rear wheel, back of number plate and bottom of the tail though 👌🏻 Quote Link to comment Share on other sites More sharing options...
marvin Posted June 3, 2021 Report Share Posted June 3, 2021 (edited) Got some banana flavoured chain lube currently. It’s got a picture of a monkey on the can. Most appropriate really. It’s actually been pretty good. Edited June 3, 2021 by marvin Quote Link to comment Share on other sites More sharing options...
426hemi Posted June 3, 2021 Report Share Posted June 3, 2021 5 minutes ago, marvin said: Got some banana flavoured chain lube currently. It’s go a picture of a monkey on the can. Most appropriate really. It’s actually been pretty good. How long did it take before you licked it then? 1 Quote Link to comment Share on other sites More sharing options...
Pinkbike1 Posted June 3, 2021 Report Share Posted June 3, 2021 36 minutes ago, marvin said: Got some banana flavoured chain lube currently. It’s got a picture of a monkey on the can. Most appropriate really. It’s actually been pretty good. You sure it's chain lube? Just saying like Quote Link to comment Share on other sites More sharing options...
marvin Posted June 4, 2021 Report Share Posted June 4, 2021 9 hours ago, Pinkbike1 said: You sure it's chain lube? Just saying like Its this one. The other one for mutual pleasure is strawberry flavour obviously. 1 Quote Link to comment Share on other sites More sharing options...
Timbo S2 Posted June 4, 2021 Report Share Posted June 4, 2021 20 hours ago, nampus said: I'm on my first can of S100 dry lube, always used regular chain lube before. Is it a dry lube thing that the rollers on the chain are shiny within about 300km's/180miles? Often sooner. I always used shiny rollers as an indicator that the chain needs lubing. And it seems the dry lube does not last very long. No more crap on the rear wheel, back of number plate and bottom of the tail though 👌🏻 I've always used Wurth dry lube, and my rollers are always shiny. 1 1 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted June 5, 2021 Report Share Posted June 5, 2021 I use wurth too. I guess the real problem us you can see when it needs doing Quote Link to comment Share on other sites More sharing options...
bignige Posted June 5, 2021 Report Share Posted June 5, 2021 I must be the only one who wasn't impressed with the Wurth stuff. I'm currently using xcp stuff Quote Link to comment Share on other sites More sharing options...
Thunderbolt Posted June 6, 2021 Report Share Posted June 6, 2021 I still use old oil and a brush at home. Away I have little cans of Silkolene. I have a can of the Würth stuff too. Quote Link to comment Share on other sites More sharing options...
nobeard Posted June 6, 2021 Report Share Posted June 6, 2021 No matter what I've tried over the years lube wise, I always end up reverting back to gear oil. Quote Link to comment Share on other sites More sharing options...
Jenny Pryde Posted June 6, 2021 Report Share Posted June 6, 2021 Doesn't it irritate your skin? Quote Link to comment Share on other sites More sharing options...
simon young Posted June 7, 2021 Report Share Posted June 7, 2021 Morris do decent stuff gets inside doesn't just sit on the chain Quote Link to comment Share on other sites More sharing options...
ZXRRDave Posted June 8, 2021 Report Share Posted June 8, 2021 Motul Factory line here, always worked well on the race bikes. Quote Link to comment Share on other sites More sharing options...
Alpinestarhero Posted June 10, 2021 Report Share Posted June 10, 2021 I'm using a castrol racing chain lubricant. I was using the wurth stuff, but I wanst really sure when it needed redoing so I was going through loads of it. The castrol stuff seems quite good. Quote Link to comment Share on other sites More sharing options...
