Pinkbike1 Posted April 3, 2021 Report Share Posted April 3, 2021 In line with the new ruling for trackdays I've bought a brake lever protector, However upon trying to fit it I can't remove the insert inside the clip on. Any suggestions ? slide hammer and knock it out or just knock it further into the clip on? it's a standard clipon, bike is an '04 600RR. I have thought about asking a responsible adult but ............ Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted April 3, 2021 Report Share Posted April 3, 2021 Fire....and violence. 2 Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted April 3, 2021 Report Share Posted April 3, 2021 The correct answer though, sadly..is that Bars are actually crash protectors, so need after market and some spare tubes. Quote Link to comment Share on other sites More sharing options...
Alex_H Posted April 3, 2021 Report Share Posted April 3, 2021 (edited) https://www.600rr.net/threads/how-to-replace-grips-and-bar-ends-on-a-cbr600rr-with-driven-d3.281782/ Bit of heat in the bar wouldn't go amiss to make the rubber a bit softer. Out of interest though can you not just put the bolt from your protector through into the existing insert? Its what I've done on my R1, assisted by some washers to clear the grip. Edited April 3, 2021 by Alex_H 1 1 Quote Link to comment Share on other sites More sharing options...
Pinkbike1 Posted April 3, 2021 Author Report Share Posted April 3, 2021 43 minutes ago, Mark/Foggy said: The correct answer though, sadly..is that Bars are actually crash protectors, so need after market and some spare tubes. I knew there was a reason why I’d worked that over time! Quote Link to comment Share on other sites More sharing options...
Pinkbike1 Posted April 3, 2021 Author Report Share Posted April 3, 2021 21 minutes ago, Alex_H said: https://www.600rr.net/threads/how-to-replace-grips-and-bar-ends-on-a-cbr600rr-with-driven-d3.281782/ Bit of heat in the bar wouldn't go amiss to make the rubber a bit softer. Out of interest though can you not just put the bolt from your protector through into the existing insert? Its what I've done on my R1, assisted by some washers to clear the grip. I did think about doing that but for some reason my addled brain rejected it 🤷♂️ Quote Link to comment Share on other sites More sharing options...
lesviffer 750 Posted April 3, 2021 Report Share Posted April 3, 2021 Better still, junk them heavy old bars and fit some nice ally clip-ons. Quote Link to comment Share on other sites More sharing options...
pirks Posted April 3, 2021 Report Share Posted April 3, 2021 I know it's not a 600rr but Honda use the same retaining clips for many bikes 1 Quote Link to comment Share on other sites More sharing options...
Pinkbike1 Posted April 4, 2021 Author Report Share Posted April 4, 2021 16 hours ago, lesviffer 750 said: Better still, junk them heavy old bars and fit some nice ally clip-ons. 🤔🤔 Quote Link to comment Share on other sites More sharing options...
