Novarally Posted December 29, 2020 Report Share Posted December 29, 2020 Be gentle with me as I'm a relative newcomer to bike mechanics (ok, I can take them apart quite well but this time it has to go back together). Today I finally got around to replacing the rear shock in my Daytona 675. This is the standard damper which came out, and what I assume to be a standard suspension linkage; I thought while it was out I would clean things, check the bearings and re-grease. I have a nice Nitron shock to go in there instead; Then I remembered that in the box of bits which came with the bike originally, I have this alternative linkage (which is quite a bit shorter) than what I believe to be the standard (black) one. So, which one should I be using? Given that I use the bike on the road and am frankly a bit slow. Quote Link to comment Share on other sites More sharing options...
nampus Posted December 29, 2020 Report Share Posted December 29, 2020 A quick search resulted in this: https://www.675.cc/threads/trs-linear-linkage.28790/ The black one looks like a trs linear linkage. The short one is the standard one. 1 Quote Link to comment Share on other sites More sharing options...
Novarally Posted December 29, 2020 Author Report Share Posted December 29, 2020 (edited) 16 minutes ago, nampus said: A quick search resulted in this: https://www.675.cc/threads/trs-linear-linkage.28790/ The black one looks like a trs linear linkage. The short one is the standard one. Interesting, thank-you so much for that. I was totally the wrong way round in my thinking then, I already had an aftermarket linkage on the bike. Seems to be a bit of confusion as to the correct orientation of the TRS one, but I shall have to research that further. Good job I asked. When I got the bike originally it had a Maxton NR4 shock on it, along with a few other modified bits, so it's not a complete surprise that someone has been playing previously. Edited December 29, 2020 by Novarally 1 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted January 3, 2021 Report Share Posted January 3, 2021 Maybe it's the pic but the new shock looks shorter ... ??? If that's the case then maybe the black linkage is for that shock ??? Quote Link to comment Share on other sites More sharing options...
Novarally Posted January 12, 2021 Author Report Share Posted January 12, 2021 All back together now, thanks. I've not had a test ride yet with the Nitron as I have the braking system in bits. See separate thread. 1 Quote Link to comment Share on other sites More sharing options...
