zxrob Posted November 1, 2020 Report Share Posted November 1, 2020 Hi folks Doing the valve clearances , 05 zx6r, some shims need changing, done it before on my old zx6r, same principal, however, put t all back together, lined the cam marks up, fired it up and it rattles like holy fook, and when you rev it, it revs slightly, then cuts out, have I some how managed to get the timing out. I have got everything off again now down to the cams, they are still in place, I have noticed that the pins on the chain dont line up where they should according to the manual, any advice Cheers Rob Quote Link to comment Share on other sites More sharing options...
wavey Posted November 2, 2020 Report Share Posted November 2, 2020 Was it still at TDC when you refitted the cams? Easy enough to get it wrong but there is definitely something wrong so strip it out again and re check everything including the clearances in case one of the shims isn't sat right Quote Link to comment Share on other sites More sharing options...
Damnthistinleg Posted November 2, 2020 Report Share Posted November 2, 2020 Did @theo do the timing for you? 1 1 Quote Link to comment Share on other sites More sharing options...
theo Posted November 2, 2020 Report Share Posted November 2, 2020 It'll run, just not how it should... Quote Link to comment Share on other sites More sharing options...
zxrob Posted November 2, 2020 Author Report Share Posted November 2, 2020 10 hours ago, wavey said: Was it still at TDC when you refitted the cams? Easy enough to get it wrong but there is definitely something wrong so strip it out again and re check everything including the clearances in case one of the shims isn't sat right In the process of going through things again When you consider I,ve done shims before, removed the cams, put it all back together, not had a problem, its fooking annoying, you keep questioning your sanity😒 Rob Quote Link to comment Share on other sites More sharing options...
Doomkinder Posted November 3, 2020 Report Share Posted November 3, 2020 My b1 was getting really noisy, the cam chain was a bit loose and the tensioner had released onto the next ratchet tooth. You probably know this but if you undo the top mounting bolt a decent way and then wind out the bottom one very carefully until it clicks just once it should do its job again. Made mine nice and quiet again. Quote Link to comment Share on other sites More sharing options...
coombehouse Posted November 3, 2020 Report Share Posted November 3, 2020 After you put the cams & tensioner in, it's a good idea to wind the motor over by hand a few revolutions & check that everything still lines up correctly. Quote Link to comment Share on other sites More sharing options...
zxrob Posted November 7, 2020 Author Report Share Posted November 7, 2020 Just an update folks All back together and running fine, I think I must not have got the chain taught on the exhaust side and it skipped a tooth when I first put it back together, thanks for your input guys Rob 5 Quote Link to comment Share on other sites More sharing options...
