MarkB Posted October 17, 2020 Report Share Posted October 17, 2020 Never had to do this before so looking for some forum wisdom on how to do it and what to use. Bike has been stood for sometime and the petrol left in there was like dark brown piss!! Quote Link to comment Share on other sites More sharing options...
426hemi Posted October 17, 2020 Report Share Posted October 17, 2020 This always gets a good review. https://www.bilthamber.com/deox-c 1 Quote Link to comment Share on other sites More sharing options...
Timbo S2 Posted October 17, 2020 Report Share Posted October 17, 2020 Check out tank care products https://www.tankcareproducts.co.uk/ they’ve just done a full resoration on my srad tank. You can buy products from them also and do it yourself. Once clean, I’d look at a protective coating too... Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted October 17, 2020 Report Share Posted October 17, 2020 I use Deox-C. So drain the tank and let it dry out. Use a drill extension and a small wire wheel to get as much of the rust as possible. Take off the tap and possibly the fuel level sender, shake as much rust out as possible then put it in your bath and flush it with water. It helps to take the shower head off the pipe 😉. Put the tap back on, turn your boiler hot water to max and fill to over half. Boil a kettle and mix the deox-c then add it to the tank ... leave overnight. Next day turn the tank upside down ( put bubble wrap under it) and leave again. Wait till the missus complains take the tap off again, empty the tank then flush out. Leave it overnight to dry out a bit. Next day fold some toilet paper and tape it to a stick use a torch and soak any water and rust up. Chuck some methylated spirit in to soak the last water up. 5 Quote Link to comment Share on other sites More sharing options...
bignige Posted October 17, 2020 Report Share Posted October 17, 2020 43 minutes ago, Evilchicken0 said: I use Deox-C. So drain the tank and let it dry out. Use a drill extension and a small wire wheel to get as much of the rust as possible. Take off the tap and possibly the fuel level sender, shake as much rust out as possible then put it in your bath and flush it with water. It helps to take the shower head off the pipe 😉. Put the tap back on, turn your boiler hot water to max and fill to over half. Boil a kettle and mix the deox-c then add it to the tank ... leave overnight. Next day turn the tank upside down ( put bubble wrap under it) and leave again. Wait till the missus complains take the tap off again, empty the tank then flush out. Leave it overnight to dry out a bit. Next day fold some toilet paper and tape it to a stick use a torch and soak any water and rust up. Chuck some methylated spirit in to soak the last water up. Plumbing by Dennis Nilsen. 🙂 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted October 17, 2020 Report Share Posted October 17, 2020 2 hours ago, bignige said: Plumbing by Dennis Nilsen. 🙂 It's just coffee grounds I added it for effect 😉 1 Quote Link to comment Share on other sites More sharing options...
MarkB Posted October 18, 2020 Author Report Share Posted October 18, 2020 16 hours ago, Evilchicken0 said: I use Deox-C. So drain the tank and let it dry out. Use a drill extension and a small wire wheel to get as much of the rust as possible. Take off the tap and possibly the fuel level sender, shake as much rust out as possible then put it in your bath and flush it with water. It helps to take the shower head off the pipe 😉. Put the tap back on, turn your boiler hot water to max and fill to over half. Boil a kettle and mix the deox-c then add it to the tank ... leave overnight. Next day turn the tank upside down ( put bubble wrap under it) and leave again. Wait till the missus complains take the tap off again, empty the tank then flush out. Leave it overnight to dry out a bit. Next day fold some toilet paper and tape it to a stick use a torch and soak any water and rust up. Chuck some methylated spirit in to soak the last water up. Not sure the Mrs will appreciate me using the bath, but I'll give it a go..... 1 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted October 18, 2020 Report Share Posted October 18, 2020 4 minutes ago, MarkB said: Not sure the Mrs will appreciate me using the bath, but I'll give it a go..... I live in a flat and rent a council garage so some stuff has to be done where theres leccy and hot water. Quote Link to comment Share on other sites More sharing options...
hybrid400 Posted October 18, 2020 Report Share Posted October 18, 2020 +1 on the deox c,easy to use and great results,did my TRX tank and sons 125 varadero tank with great success Quote Link to comment Share on other sites More sharing options...
MarkB Posted October 26, 2020 Author Report Share Posted October 26, 2020 On 10/17/2020 at 6:11 PM, Evilchicken0 said: I use Deox-C. So drain the tank and let it dry out. Use a drill extension and a small wire wheel to get as much of the rust as possible. Take off the tap and possibly the fuel level sender, shake as much rust out as possible then put it in your bath and flush it with water. It helps to take the shower head off the pipe 😉. Put the tap back on, turn your boiler hot water to max and fill to over half. Boil a kettle and mix the deox-c then add it to the tank ... leave overnight. Next day turn the tank upside down ( put bubble wrap under it) and leave again. Wait till the missus complains take the tap off again, empty the tank then flush out. Leave it overnight to dry out a bit. Next day fold some toilet paper and tape it to a stick use a torch and soak any water and rust up. Chuck some methylated spirit in to soak the last water up. Yep, +1 for Deoux-c. Didn't use the bath to flush it but did use her hairdryer to help dry it out 😄 1 1 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted October 27, 2020 Report Share Posted October 27, 2020 14 hours ago, MarkB said: Yep, +1 for Deoux-c. Didn't use the bath to flush it but did use her hairdryer to help dry it out 😄 I did that on another tank but thought I'd try meths on this one Quote Link to comment Share on other sites More sharing options...
bignige Posted October 27, 2020 Report Share Posted October 27, 2020 4 hours ago, Evilchicken0 said: I did that on another tank but thought I'd try meths on this one Cocktails with any Leftovers. 🙂👍 1 Quote Link to comment Share on other sites More sharing options...
Mr.Incredible Posted October 27, 2020 Report Share Posted October 27, 2020 White vinegar works amazingly at getting rid of old petrol and rust. I had a bike with a very rusty tank that was half full of stinking, years-old petrol. - white vinegar brought it up like new. Bought from Tesco, cost fuck all. 2 1 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted October 27, 2020 Report Share Posted October 27, 2020 Cool - 1kg is about £15 +pnp should be enough to do 2 tanks. Quote Link to comment Share on other sites More sharing options...
MarkB Posted October 27, 2020 Author Report Share Posted October 27, 2020 1 hour ago, Evilchicken0 said: Cool - 1kg is about £15 +pnp should be enough to do 2 tanks. That's what I bought, and have used about half so enough left for the next old shitter/restoration project I convince myself is worth saving 1 Quote Link to comment Share on other sites More sharing options...
Mr.Incredible Posted October 28, 2020 Report Share Posted October 28, 2020 A pint of white vinegar from Tesco costs 40p... Quote Link to comment Share on other sites More sharing options...
bignige Posted October 28, 2020 Report Share Posted October 28, 2020 Cheers! Quote Link to comment Share on other sites More sharing options...
coombehouse Posted October 28, 2020 Report Share Posted October 28, 2020 I've used deox-c or white vinegar on lightly rusted tanks but for more rusty things, brick acid works better if you have plenty of metal thickness to work with & is quick. Electrolysis is best for non aggressive rust removal though. 2 Quote Link to comment Share on other sites More sharing options...
