hylar1000 Posted September 6, 2020 Report Posted September 6, 2020 Do any of the anorak types happen to know which forks from later bikes are a straight swap into K1 thou forks? Also, is the rear shock a straight swap with later models and do later models have more adjustability? Quote
TLRS Posted September 7, 2020 Report Posted September 7, 2020 Pretty sure 1000k1 has 207mm fork spacing. And if they’re 50/54mm forks, up to 1000k6 is 50/54mm and 207mm too. 1000k7/k8 is 50/56. If you don’t mind fiddling with lockstops/steering lock, get the yokes to go with it.. might slot in from bearing/stemlength pov. Offsets varies too. K1 ought to be 32mm. K7/8 28mm. Have a search for “Sam’s fork chart” for more info, it’s legendary. 1 1 Quote
Damnthistinleg Posted September 7, 2020 Report Posted September 7, 2020 4 hours ago, TLRS said: Have a search for “Sam’s fork chart” for more info, it’s legendary. ^^^ What he says. Also note that the BPF forks from the K9 thou onwards are 50/55. I've no idea once we get into the more recent stuff though. 1 Quote
hylar1000 Posted September 9, 2020 Author Report Posted September 9, 2020 On 9/7/2020 at 6:32 AM, TLRS said: Pretty sure 1000k1 has 207mm fork spacing. And if they’re 50/54mm forks, up to 1000k6 is 50/54mm and 207mm too. 1000k7/k8 is 50/56. If you don’t mind fiddling with lockstops/steering lock, get the yokes to go with it.. might slot in from bearing/stemlength pov. Offsets varies too. K1 ought to be 32mm. K7/8 28mm. Have a search for “Sam’s fork chart” for more info, it’s legendary. Cheers 👍 1 Quote
coombehouse Posted September 11, 2020 Report Posted September 11, 2020 Can I ask why you want to change the forks? Rear shock, the k3 & k4 will fit but the length is slightly different. With an ohlins, this can be adjusted out. 1 Quote
Timbo S2 Posted September 11, 2020 Report Posted September 11, 2020 I used Sams Fork chart when I changed forks on the srad - twice. K5 600 forks fit straight in, k7 750 forks needed a new bottom yoke (IIRC). I assume you want radial calipers? Quote
hylar1000 Posted September 11, 2020 Author Report Posted September 11, 2020 2 hours ago, coombehouse said: Can I ask why you want to change the forks? Rear shock, the k3 & k4 will fit but the length is slightly different. With an ohlins, this can be adjusted out. It would be for a better selection of calipers, also I'm curious and I like to tinker. Cheers for the info on the rear shock. 1 Quote
hylar1000 Posted September 11, 2020 Author Report Posted September 11, 2020 3 hours ago, Timbo S2 said: I used Sams Fork chart when I changed forks on the srad - twice. K5 600 forks fit straight in, k7 750 forks needed a new bottom yoke (IIRC). I assume you want radial calipers? It's a thought for the future, also I need to get stiffer springs for my dainty body😊, so I wanted to know if fork springs would be interchangeable. K3-6 Seem to be the same fork with a different bottom where the calipers attaches . Quote
Timbo S2 Posted September 11, 2020 Report Posted September 11, 2020 Think there’s a difference in fork lower diameter k6-k7 onwards. Need to shim about 1mm from memory. Or have cnc’d bottom yoke like I stupidly did... Quote
hylar1000 Posted September 11, 2020 Author Report Posted September 11, 2020 20 minutes ago, Timbo S2 said: Think there’s a difference in fork lower diameter k6-k7 onwards. Need to shim about 1mm from memory. Or have cnc’d bottom yoke like I stupidly did... The chart shows the offset as different on the k5-6 and the fork spacing being diffrent, the k3-6 are 6mm shorter which should be fine given the amount of top showing on my k1. As a fork though k3-6 look to drop right in. Quote
hylar1000 Posted September 11, 2020 Author Report Posted September 11, 2020 1 minute ago, TLRS said: K3-6.. 600/750? 1000 Quote
TLRS Posted September 11, 2020 Report Posted September 11, 2020 Ah yes..all 50/54mm.. I think the k3/4 forks have bigger pistons, which was suggested as favourable. 1 Quote
hylar1000 Posted September 11, 2020 Author Report Posted September 11, 2020 49 minutes ago, TLRS said: Ah yes..all 50/54mm.. I think the k3/4 forks have bigger pistons, which was suggested as favourable. Bigger pistols? Quote
TLRS Posted September 12, 2020 Report Posted September 12, 2020 Yeah oil flow piston thingy. That’s why they went to ‘big piston’ fork designs later. Iirc k3/4 is 25mm, k5/6 20mm? 1 Quote
TLRS Posted September 15, 2020 Report Posted September 15, 2020 That’d be Sam’s chart sans credits.. bastards. Shows TL discs have no offset, pretty sure that it’s 0,5mm. Quote
Frosty_The_Iceman Posted September 15, 2020 Report Posted September 15, 2020 Got it off the SV Rider forms probably 10 years ago when I did my fork swap. I've always seen it referred to as the "Sam chart", didn't know it had been edited. Quote
Damnthistinleg Posted September 15, 2020 Report Posted September 15, 2020 On 9/11/2020 at 5:36 PM, Timbo S2 said: Think there’s a difference in fork lower diameter k6-k7 onwards. Need to shim about 1mm from memory. Or have cnc’d bottom yoke like I stupidly did... The correct answer to your problem was 'Harris'. Quote
