couchcommando Posted September 6, 2020 Report Share Posted September 6, 2020 The Royal Enfield has an 18” front wheel with a 320mm Brembo disc, looks very similar to a Ducati monster disc. The caliper is a 2 pot sliding budget bybre Brembo. Works ok and also looks very similar to an early cb500 Brembo. Would like a 4 pot caliper, only tried a gold line Brembo but there’s not enough clearance as the inner side touches the spokes. So anyone know of any slim 4 pot calipers that may have a chance of fitting ? Quote Link to comment Share on other sites More sharing options...
Thunderbolt Posted September 6, 2020 Report Share Posted September 6, 2020 30 minutes ago, couchcommando said: The Royal Enfield has an 18” front wheel with a 320mm Brembo disc, looks very similar to a Ducati monster disc. The caliper is a 2 pot sliding budget bybre Brembo. Works ok and also looks very similar to an early cb500 Brembo. Would like a 4 pot caliper, only tried a gold line Brembo but there’s not enough clearance as the inner side touches the spokes. So anyone know of any slim 4 pot calipers that may have a chance of fitting ? Braking do some slim ones. 1 Quote Link to comment Share on other sites More sharing options...
Superdunc Posted September 6, 2020 Report Share Posted September 6, 2020 Typical supermoto issue. Beringer as sugested, or speak to @Kayla about her disc shims to move the disc out 2-3mm. Supermoto guys used to grind the back off the caliper to gain 0.5mm . Quote Link to comment Share on other sites More sharing options...
couchcommando Posted September 6, 2020 Author Report Share Posted September 6, 2020 23 minutes ago, Superdunc said: Typical supermoto issue. Beringer as sugested, or speak to @Kayla about her disc shims to move the disc out 2-3mm. Supermoto guys used to grind the back off the caliper to gain 0.5mm . I’ll look at SM stuff, disc can’t be moved due to abs sensor bracket 👍 Quote Link to comment Share on other sites More sharing options...
Superdunc Posted September 6, 2020 Report Share Posted September 6, 2020 9 minutes ago, couchcommando said: I’ll look at SM stuff, disc can’t be moved due to abs sensor bracket 👍 Can you incorporate a new abs sensor mount into the caliper adaptor? Quote Link to comment Share on other sites More sharing options...
Kayla Posted September 6, 2020 Report Share Posted September 6, 2020 What side's the disc on? Aprilia RS125 calipers are pretty skinny and work well. Quote Link to comment Share on other sites More sharing options...
couchcommando Posted September 6, 2020 Author Report Share Posted September 6, 2020 6 hours ago, Kayla said: What side's the disc on? Aprilia RS125 calipers are pretty skinny and work well. Lhs sat on bike Quote Link to comment Share on other sites More sharing options...
Kayla Posted September 7, 2020 Report Share Posted September 7, 2020 Ah, wrong side then Quote Link to comment Share on other sites More sharing options...
