Halvasso boy Posted September 5, 2020 Report Share Posted September 5, 2020 Allways seem to be in trouble with Aprilia,s . Got the gearbox sorted after waiting two months for parts . Went out for celebration ride and all was right with the world . On my third ride out missed 6th gear and over reved , motor cut out straight away and urgent service flashed on dash . Went for a restart and motor not turning over , after leaving it for 10 mins. turned over slowly . When I went back to pick it up an hour later it turned over but would not start . Back in the garage fault code on dash 08 oil pressure . Checked oil pump drive as I removed it to replace the gearbox cleared the code still no start and urgent service flashed on dash . Have removed plugs and rocker covers but everything looks ok . My Mrs said burn it . So my question is do I burn the fucking thing or no ? A 1 Quote Link to comment Share on other sites More sharing options...
hawkati Posted September 5, 2020 Report Share Posted September 5, 2020 12 minutes ago, Halvasso boy said: Allways seem to be in trouble with Aprilia,s . Got the gearbox sorted after waiting two months for parts . Went out for celebration ride and all was right with the world . On my third ride out missed 6th gear and over reved , motor cut out straight away and urgent service flashed on dash . Went for a restart and motor not turning over , after leaving it for 10 mins. turned over slowly . When I went back to pick it up an hour later it turned over but would not start . Back in the garage fault code on dash 08 oil pressure . Checked oil pump drive as I removed it to replace the gearbox cleared the code still no start and urgent service flashed on dash . Have removed plugs and rocker covers but everything looks ok . My Mrs said burn it . So my question is do I burn the fucking thing or no ? A paging @wavey to the fukkered Aprilia phone - bring matches! 2 Quote Link to comment Share on other sites More sharing options...
Halvasso boy Posted September 5, 2020 Author Report Share Posted September 5, 2020 Can of petrol and matches on standby . 1 Quote Link to comment Share on other sites More sharing options...
tootall Posted September 5, 2020 Report Share Posted September 5, 2020 Twin or V4? Quote Link to comment Share on other sites More sharing options...
wavey Posted September 5, 2020 Report Share Posted September 5, 2020 V4 I assume. If so, do you have guzzi diag to plug in and get the fault codes? The program is free and the cables about £25. When it turns over does it makes any unusual noises (baring in mind they sound broken even when working correctly) I have access to a nice deep canal if the matches don't do the job 2 Quote Link to comment Share on other sites More sharing options...
marvin Posted September 6, 2020 Report Share Posted September 6, 2020 Burn it. Will never buy an Aprilia. Quote Link to comment Share on other sites More sharing options...
Bram43 Posted September 6, 2020 Report Share Posted September 6, 2020 15 hours ago, wavey said: V4 I assume. If so, do you have guzzi diag to plug in and get the fault codes? The program is free and the cables about £25. When it turns over does it makes any unusual noises (baring in mind they sound broken even when working correctly) I have access to a nice deep canal if the matches don't do the job The forty foot near me preferred R1’s and RF600’s (right place for’em). Set fire to it and replace it with a new Tuono. 1 Quote Link to comment Share on other sites More sharing options...
Halvasso boy Posted September 6, 2020 Author Report Share Posted September 6, 2020 It's a 2011 v4r aprc . Immobilizer light is flashing . Just don't know why an over reved would cause this or was that just a coincidence . Once it's on fire I'm pushing it into a mine shaft and filling it in . Quote Link to comment Share on other sites More sharing options...
HOGG Posted September 6, 2020 Report Share Posted September 6, 2020 Snapped belt? Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted September 6, 2020 Report Share Posted September 6, 2020 Maybe it could just roll off it's side stand into a handy ravine, Insurance company should pay out for that one, I think that they're getting suspicious of self igniting Italian bikes. Unless it happens to be next to an MV and gets caught in the conflagration. 'They all do that Sir'. On a more practical note, I'd be worried about the over rev and then following symptoms. The ECU might be having a hissy fit, but should have remained consistent from the moment it happened. I'd be running a compression tester over it. Quote Link to comment Share on other sites More sharing options...
Jenny Pryde Posted September 6, 2020 Report Share Posted September 6, 2020 Character. You'll laugh about it in years to come. Maybe. 1 Quote Link to comment Share on other sites More sharing options...
Superdunc Posted September 6, 2020 Report Share Posted September 6, 2020 Shouldn't over rev missing a gear. That's what the rev limiteris there for. Quote Link to comment Share on other sites More sharing options...
Halvasso boy Posted September 13, 2020 Author Report Share Posted September 13, 2020 Going to download guzzidiag to see if it has any answers . Quote Link to comment Share on other sites More sharing options...
srad34 Posted September 13, 2020 Report Share Posted September 13, 2020 Change the oil and filters....... .... It is in no way going to fix the bike but it will distract you and make you feel all special like a someone panning for precious metals with a sieve 😉 1 9 Quote Link to comment Share on other sites More sharing options...
jollygiant Posted September 13, 2020 Report Share Posted September 13, 2020 5 hours ago, srad34 said: Change the oil and filters....... .... It is in no way going to fix the bike but it will distract you and make you feel all special like a someone panning for precious metals with a sieve 😉 You've owned many Aprilia's by the sound of it then!! 1 Quote Link to comment Share on other sites More sharing options...
Bram43 Posted September 13, 2020 Report Share Posted September 13, 2020 6 hours ago, srad34 said: Change the oil and filters....... .... It is in no way going to fix the bike but it will distract you and make you feel all special like a someone panning for precious metals with a sieve 😉 Best laugh I’d had in ages Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted September 13, 2020 Report Share Posted September 13, 2020 On 9/6/2020 at 6:13 PM, Superdunc said: Shouldn't over rev missing a gear. That's what the rev limiteris there for. If it pops down to a lower gear, limiter will not always catch it... Quote Link to comment Share on other sites More sharing options...
Superdunc Posted September 13, 2020 Report Share Posted September 13, 2020 2 minutes ago, Mark/Foggy said: If it pops down to a lower gear, limiter will not always catch it... How does it pop to a lower gear when attempting to change up. Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted September 13, 2020 Report Share Posted September 13, 2020 Good point Quote Link to comment Share on other sites More sharing options...
Damnthistinleg Posted September 14, 2020 Report Share Posted September 14, 2020 (edited) Road shift/race shift brainfart. I did it on my old Mille while leaned over and accelerating through that big long sweeping right-hander at Cartagena. I nearly highsided myself into the Mediterranean but just caught it on the clutch before the point of no return. A real brown trouser moment, that one. Edited September 14, 2020 by Damnthistinleg Quote Link to comment Share on other sites More sharing options...
Superdunc Posted September 14, 2020 Report Share Posted September 14, 2020 4 minutes ago, Damnthistinleg said: Road shift/race shift brainfart. Indeed, but that's not what is being described here. If the OP has gone 4th instead of 6th at full chat, well, it's time for valves pistons and big ends. Quote Link to comment Share on other sites More sharing options...
Damnthistinleg Posted September 14, 2020 Report Share Posted September 14, 2020 That is true but I just wanted to relay an anecdote of my track-riding fuckwittery. 1 1 Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted September 18, 2020 Report Share Posted September 18, 2020 And I should have read the thread properly. But, Priller so is probably in the ECU to extract maximum pain from ownership. Please don't hate me. Quote Link to comment Share on other sites More sharing options...
theo Posted September 20, 2020 Report Share Posted September 20, 2020 On 9/13/2020 at 12:28 PM, Halvasso boy said: Going to download guzzidiag to see if it has any answers . Take the fuse out of the headlight array(located under the seat) unless you've got the battery on a trickle charger. Whats its saying? Quote Link to comment Share on other sites More sharing options...
wavey Posted September 22, 2020 Report Share Posted September 22, 2020 Is it for sale cheap yet? 1 Quote Link to comment Share on other sites More sharing options...
Halvasso boy Posted September 26, 2020 Author Report Share Posted September 26, 2020 From this point on it shall be know as the bastard . Well it's fixed . Ordered a fly lead off that their eBay , plugged in an old scan tool from work , cleared fault codes . Hey presto the bastard starts . Got a little over excited and forgot to note down fault codes. Why do I keep punching myself in the head . Because it's great when you stop . 1 Quote Link to comment Share on other sites More sharing options...
