Leaky Carbs - FCR related
Toneale
The fireblade has an annoying leak coming from the FCR's. I thought I had it cured after giving the carb bowls a good clean but apparently my confidence was misplaced.
When the fuel pump primes it normally stops once the carbs are full, however, I can still hear a click from the pump every 5 seconds or so.
I am assuming that it's probably the needle valve either sticking or not sealing properly but is there any thing else that could cause the leak?
Ta muchly :thumbsup:
Guest
Reply to this topic...
  Only 75 emoji are allowed.
