Mark/Foggy Posted August 2, 2020 Report Share Posted August 2, 2020 So I'm working on Cupcakes headlight cluster, but hit a stumbling block The adjusters are ball ended,approx 7.2 mm, which is odd in itself. So I rammed some holes in my Carbon plate and expected the ball to fit into the supplied clips. Only they don't click in Now you can't get the clip onto the threaded adjuster rod itself because the through hole is smaller than either end of the adjuster. Also the clip doesn't really have a n internal profile that would retain the ball anyway. So, I'm at a complete impass. Anybody think of a retainer that I could push into service here?? Or am I just being monumentally thick? Quote Link to comment Share on other sites More sharing options...
426hemi Posted August 2, 2020 Report Share Posted August 2, 2020 (edited) Mine became loose on my rsv so I put lock wire round them to pull them tighter. Edited August 2, 2020 by 426hemi Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted August 2, 2020 Author Report Share Posted August 2, 2020 13 minutes ago, 426hemi said: Mine became loose on my rsv so I put lock wire round them to pull them tighter. So, does the rsv use these clips or are the Priller ones worth a look? I am kind of thinking that I've seen a receptacle that has a tabbed E clip that would be appropriate, but I have no idea where I saw it.. Quote Link to comment Share on other sites More sharing options...
426hemi Posted August 2, 2020 Report Share Posted August 2, 2020 Same clips, maybe the heat over the years relaxes the clip, it was really awkward to get the lock wire around it but it did work or you could try some bacofoil round the ball end to make it bigger. Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted August 2, 2020 Author Report Share Posted August 2, 2020 I can't even get the ball to locate and retain. I've tried in a couple of hole sizes, the landing on the exterior diameter of the clip is for a thin material, so it should work, but genuinely not working for me. It needs a different solution. I'm casting around for ideas. Quote Link to comment Share on other sites More sharing options...
TLRS Posted August 2, 2020 Report Share Posted August 2, 2020 Can you pull anything through from t’other side? Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted August 2, 2020 Author Report Share Posted August 2, 2020 I have both sides of a plate to work with here, and have 10mm holes drilled through that carbon plate, I am just not sure what to do next.. Quote Link to comment Share on other sites More sharing options...
HOGG Posted August 2, 2020 Report Share Posted August 2, 2020 Drill a little hole in the end of the ball and then once in the clip, get a little tiny screw in the hole. Quote Link to comment Share on other sites More sharing options...
Superdunc Posted August 2, 2020 Report Share Posted August 2, 2020 I think your missing some parts. Ill have a look at a similar set of hella I have tucked away. Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted August 2, 2020 Author Report Share Posted August 2, 2020 4 minutes ago, HOGG said: Drill a little hole in the end of the ball and then once in the clip, get a little tiny screw in the hole. Good thinking batman, but I'm sure that there must be a proprietary solution out there, 1 Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted August 2, 2020 Author Report Share Posted August 2, 2020 1 minute ago, Superdunc said: I think your missing some parts. Ill have a look at a similar set of hella I have tucked away. Thanks Dunc, something is nor right here. I have the clips that mount the adjusters to the shell, which are a strange single use moulding that comes pre mounted on the adjuster screws, but all of the supplied components came out of single bag. Quote Link to comment Share on other sites More sharing options...
Swarf Posted August 3, 2020 Report Share Posted August 3, 2020 (edited) @Mark/Foggy Is the clip tapered at all? I'm just wondering if you need a smaller hole but assemble the clip onto the ball, then push the whole thing through so the front edge of the clip deforms and catches the ball? Edited August 3, 2020 by Swarf 4 Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted August 8, 2020 Author Report Share Posted August 8, 2020 Well, those clips have decided to not give me any purchase to hold the lamp, but will serve as as buckets to stop the adjusters moving around. I'm going to P clip the board and use thick O rings to pull the adjusters back into the location. should make for a neat solution and be QD enough to make for a quick repair if needed. 1 Quote Link to comment Share on other sites More sharing options...
tootall Posted August 10, 2020 Report Share Posted August 10, 2020 Do the adjuster balls click in when the plastic isn't inserted into a hole? Could the plastic be designed to be screwed/bolted down with a countersunk and then the adjusters clicked in? Quote Link to comment Share on other sites More sharing options...
Superdunc Posted August 10, 2020 Report Share Posted August 10, 2020 Looking at the Hellas I hace which are the same design, it looks like it's just down to the size of the hole in the mounting plate. Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted August 10, 2020 Author Report Share Posted August 10, 2020 It's a puzzle, they genuinely don't grip the ball. Certainly there is a landing on the outside that closes the cup and that seems to like a 10mm hole. If you install without the ball end, closure of the top hat area looks excellent and you can't push the ball into the socket. install them assembled and the location is excellent, but it won't hold the ball captive, just the weight of the unit is enough to get all 3 to just pop out. What is annoying me most about this, is that I was working on these units pressed into service on the early TT Legends bikes and remember using some circular alloy plates that were welded into an upper Fairing bracket. Now I was only playing with some of this, not involved in the overall design of the assembly, but i genuinely don't remember how it all went together. Worse still it was a design that was used on some of the Classic P1 bikes before they went total LED, but in fairness I didn't do a lot of work on those Kawasakis, I was still messing around with Italians and Bultacos.. Quote Link to comment Share on other sites More sharing options...
