leey Posted July 27, 2020 Report Share Posted July 27, 2020 So my mate has booked me on a James Whitham trackday at Mallory Park. Slightly concerned the Db limit is 98 and my little zxr 400 struggles with being a bit fruity on the 104Db. Any tips on repacking an exhaust and the best product to use. Cheers Lee Quote Link to comment Share on other sites More sharing options...
Gobert Posted July 27, 2020 Report Share Posted July 27, 2020 6 minutes ago, leey said: So my mate has booked me on a James Whitham trackday at Mallory Park. Slightly concerned the Db limit is 98 and my little zxr 400 struggles with being a bit fruity on the 104Db. Any tips on repacking an exhaust and the best product to use. Cheers Lee 6db might take a bit more than repacking? I use acousta fil. 1 Quote Link to comment Share on other sites More sharing options...
leey Posted July 27, 2020 Author Report Share Posted July 27, 2020 My can is 450mm long and I've a Baffle which I can use as well. Quote Link to comment Share on other sites More sharing options...
Gobert Posted July 27, 2020 Report Share Posted July 27, 2020 55 minutes ago, leey said: My can is 450mm long and I've a Baffle which I can use as well. That should be ok........I'm assuming it's 104 without the baffle? Quote Link to comment Share on other sites More sharing options...
leey Posted July 27, 2020 Author Report Share Posted July 27, 2020 37 minutes ago, Gobert said: That should be ok........I'm assuming it's 104 without the baffle? Yeah 104 with no baffle installed. Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 29, 2020 Report Share Posted July 29, 2020 104 is quite loud - your going to shove a baffle in there and make the fuelling rich just when youre going to use the engine full on. 1 Quote Link to comment Share on other sites More sharing options...
leey Posted July 30, 2020 Author Report Share Posted July 30, 2020 I've purchased some acousta-fil hopefly a repack will shave some Db off. Quote Link to comment Share on other sites More sharing options...
hawkati Posted July 31, 2020 Report Share Posted July 31, 2020 just baffle it. That'll take the edge off the noise and you'll not suffer from the engine being choked much. Far easier to do. Quote Link to comment Share on other sites More sharing options...
