nobeard Posted June 25, 2020 Report Share Posted June 25, 2020 Never seen this before. Just bought the TRX850 and the front brakes aren't great. No judder, bid wooden, not a lot of bite. Just bled them and a little air came out of each - should help. Fluid is newish. Pads out, 7 of the 8 pistons push back with thumb pressure but pretty clean. Pads are virtually new EBC HH, but the have a look at the wear on them - vertical ridges - quite jagged. Discs look and feel fine. I've never this before - any ideas? Quote Link to comment Share on other sites More sharing options...
Thunderbolt Posted June 25, 2020 Report Share Posted June 25, 2020 The vertical bits look like someone has scraped a hacksaw blade down them, (perhaps to remove glazing/contamination/aid bedding in) then the true wear is the front to back, so I would say Bin them. pads are cheap Quote Link to comment Share on other sites More sharing options...
nobeard Posted June 25, 2020 Author Report Share Posted June 25, 2020 (edited) I'll definitely be binning them. Just wanted to check if it could be some other issue that would cause this - and thus knack the new pair. You might be right - exactly the same pattern/width throughout. What an odd thing to do. Edited June 25, 2020 by nobeard Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted June 25, 2020 Report Share Posted June 25, 2020 Are you using blue spot calipers ??? If your going to do the pads it might be a better move to upgrade the whole system. Quote Link to comment Share on other sites More sharing options...
nobeard Posted June 25, 2020 Author Report Share Posted June 25, 2020 Yes, its got Blue Spots. The other line of thinking from a few has been it's stlll running the original master cylinder. Quote Link to comment Share on other sites More sharing options...
hybrid400 Posted June 25, 2020 Report Share Posted June 25, 2020 3 hours ago, nobeard said: Never seen this before. Just bought the TRX850 and the front brakes aren't great. No judder, bid wooden, not a lot of bite. Just bled them and a little air came out of each - should help. Fluid is newish. Pads out, 7 of the 8 pistons push back with thumb pressure but pretty clean. Pads are virtually new EBC HH, but the have a look at the wear on them - vertical ridges - quite jagged. Discs look and feel fine. I've never this before - any ideas? (Puts nerdy rivett counter hat on) If you have blue spots on your trx,the pads should be fa252,those im pretty sure are fa380,they have the same 50.4 x69x8.7mm size but according to my ebc book,ebc have them as fitment for later yams and not the early blue spots yams. 1 Quote Link to comment Share on other sites More sharing options...
