Evilchicken0 Posted June 23, 2020 Report Share Posted June 23, 2020 The problem is the 3TJ fuel pipe is getting so old they can snap. Well I made a replacement. The biggest problem is making the bends. First I cut some wire coat hangers and taped them to 300mm of 8mm ID fuel hose. Then went to a printing shop and got them to wire bind them. That meant I could bend the hose without it kinking. I bent it around a steel tube chair. After that I clipped the binding and hanger wire back so I can put the tube clips on and a flexible end for the tank. 15 2 Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted June 23, 2020 Report Share Posted June 23, 2020 Cool....Thinking outside the box is Wicked. 1 Quote Link to comment Share on other sites More sharing options...
jaycee Posted June 23, 2020 Report Share Posted June 23, 2020 @Evilchicken0, you are one clever fucker👏 1 Quote Link to comment Share on other sites More sharing options...
coombehouse Posted June 23, 2020 Report Share Posted June 23, 2020 Clever. I'm going to steal that one. 1 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted June 27, 2020 Author Report Share Posted June 27, 2020 As a little mod to this When you trim the coat hanger wire bend it back on itself first then cut it ... this will make a hook so the binding wire dosent slip off 1 Quote Link to comment Share on other sites More sharing options...
