Elohesra Posted June 22, 2020 Report Share Posted June 22, 2020 Tinkering with the SRAD, this thing has been in the shed since 2008. First job get the tank drained - yes, I know I should have done that in 2008..... Oh dear, this came out.... Followed by what used to be a fuel pump....I may be some time with this.... 2 Quote Link to comment Share on other sites More sharing options...
hawkati Posted June 22, 2020 Report Share Posted June 22, 2020 On behalf of everyone everywhere I'd just like to say Blearggh! 2 Quote Link to comment Share on other sites More sharing options...
Elohesra Posted June 22, 2020 Author Report Share Posted June 22, 2020 Indeed. Carbs should be interesting..... Quote Link to comment Share on other sites More sharing options...
Lobo Posted June 23, 2020 Report Share Posted June 23, 2020 Ooh ya fucker........ good luck with that, you may need it Quote Link to comment Share on other sites More sharing options...
DougW Posted June 24, 2020 Report Share Posted June 24, 2020 (edited) Only two like this. Edited June 24, 2020 by DougW Quote Link to comment Share on other sites More sharing options...
Elohesra Posted June 24, 2020 Author Report Share Posted June 24, 2020 6 hours ago, DougW said: Only two like this. Did you manage to salvage them? Ultrasonic cleaning? I do have another set of carbs for the SRAD if needed, but the ones on the bike were set up with much dyno time by a fuelling genius and the bike always ran beautifully. So I'd like to clean them if possible. Quote Link to comment Share on other sites More sharing options...
DougW Posted June 24, 2020 Report Share Posted June 24, 2020 3 hours ago, Elohesra said: Did you manage to salvage them? Ultrasonic cleaning? I do have another set of carbs for the SRAD if needed, but the ones on the bike were set up with much dyno time by a fuelling genius and the bike always ran beautifully. So I'd like to clean them if possible. Yes. Cheap maplin ultrasonic cleaner, lot of cycles, carb cleaner and patience. Tried the expensive ultrasonic cleaning detergent stuff, but washing up liquid seemed just as effective. LC ran , briefly, before bursting rad and pissing water everywhere when head gasket failed. Found head studs all loose. I’ll post an after pic tomorrow. Quote Link to comment Share on other sites More sharing options...
DougW Posted June 26, 2020 Report Share Posted June 26, 2020 On 6/24/2020 at 6:59 PM, Elohesra said: Did you manage to salvage them? Ultrasonic cleaning? I do have another set of carbs for the SRAD if needed, but the ones on the bike were set up with much dyno time by a fuelling genius and the bike always ran beautifully. So I'd like to clean them if possible. Nearly clean. Some more carb cleaner and ultrasonic after this. Replaced the float needle and pilots after this. Had a lot of trouble with pilots in the mx bikes, despite cleaning several times low rpm problems cured by fitting new same size pilot. Obviously not cleaning well enough , but modern fuel residue in pilots seems resistant to everything I have tried so far. 1 Quote Link to comment Share on other sites More sharing options...
