MonkeyJim Posted June 1, 2020 Report Share Posted June 1, 2020 So, I have a leak Any do's/don'ts in terms of what hose to buy? Needs to be fuel injection rated I guess, and I need 120mm to replace the section in question (I have the clips already) Quote Link to comment Share on other sites More sharing options...
Damnthistinleg Posted June 1, 2020 Report Share Posted June 1, 2020 Just wander down your nearest motor factors. They usually have fuel pipe on a roll and will cut some off for you. Quote Link to comment Share on other sites More sharing options...
DesmoEddy Posted June 1, 2020 Report Share Posted June 1, 2020 What internal diameter do you need? Note that not all fuel injection rated hose is created equal - with the increasing ethanol content in newer fuels, some hose which would previously been fine can start to break down. You might want to look at Cohline products, eg:- https://www.glencoeltd.co.uk/cohline-fuel-vacuum-hose/cohline-fuel-hose-high-pressure/ Quote Link to comment Share on other sites More sharing options...
MonkeyJim Posted June 1, 2020 Author Report Share Posted June 1, 2020 1 hour ago, DesmoEddy said: What internal diameter do you need? Note that not all fuel injection rated hose is created equal - with the increasing ethanol content in newer fuels, some hose which would previously been fine can start to break down. You might want to look at Cohline products, eg:- https://www.glencoeltd.co.uk/cohline-fuel-vacuum-hose/cohline-fuel-hose-high-pressure/ Thanks - do you think that's what's happened to mine? I can't see any signs of damage like it's been punctured externally. it's 8mm I/D Quote Link to comment Share on other sites More sharing options...
DesmoEddy Posted June 1, 2020 Report Share Posted June 1, 2020 2 hours ago, MonkeyJim said: Thanks - do you think that's what's happened to mine? I can't see any signs of damage like it's been punctured externally. it's 8mm I/D PM me your address and I'll send you some hose. 2 Quote Link to comment Share on other sites More sharing options...
MonkeyJim Posted June 1, 2020 Author Report Share Posted June 1, 2020 25 minutes ago, DesmoEddy said: PM me your address and I'll send you some hose. Thank you - PM incoming Quote Link to comment Share on other sites More sharing options...
