riversbikes Posted April 1, 2020 Report Share Posted April 1, 2020 Hey all -- quick question... will the 5-spoke rear wheel (Marchesini) from the superbikes fit the rear hub of the Ducati 796? For a custom project... Quote Link to comment Share on other sites More sharing options...
TLRS Posted April 2, 2020 Report Share Posted April 2, 2020 Almost a day, no response.. come on PB massive! Quote Link to comment Share on other sites More sharing options...
fastfreddybikes Posted April 3, 2020 Report Share Posted April 3, 2020 It’s quickly turning into a mutant mums net as foraging recipes are swapped. Biking questions are fucked until the virus burns a hole in our frilly aprons 5 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted April 3, 2020 Report Share Posted April 3, 2020 13 hours ago, TLRS said: Almost a day, no response.. come on PB massive! Maybe. If the front sprocket position is the same then your in the right ballpark. For that to be so you need a similar engine cases. Quote Link to comment Share on other sites More sharing options...
stretch Posted April 3, 2020 Report Share Posted April 3, 2020 (edited) 8 hours ago, Evilchicken0 said: Maybe. If the front sprocket position is the same then your in the right ballpark. For that to be so you need a similar engine cases. You sure this was the right thread for that response? Or are you thinking about chain run side to side? Edited April 3, 2020 by stretch cause duh... Quote Link to comment Share on other sites More sharing options...
TLRS Posted April 3, 2020 Report Share Posted April 3, 2020 Don’t these centerlock rear wheels bolt onto the hub, leaving the chainline intact? Quote Link to comment Share on other sites More sharing options...
426hemi Posted April 3, 2020 Report Share Posted April 3, 2020 They have location pegs on the back and then the large central nut. Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted April 3, 2020 Report Share Posted April 3, 2020 Is that what SSA is ... 🤯🤯🤯 I guess you count the bolt holes and use the same wheel width Quote Link to comment Share on other sites More sharing options...
Superdunc Posted April 3, 2020 Report Share Posted April 3, 2020 Theres 2 different hub sizes on the Ducati ssa. dont know which models use which though. Quote Link to comment Share on other sites More sharing options...
