couchcommando Posted April 1, 2020 Report Share Posted April 1, 2020 Looking for a bike that uses 2 twin piston calipers along with an axial master cylinder with an external reservoir. Want to change the master cylinder on the VFR which is the honda one with a built in metal reservoir. Has to be axial not radial. Guess I'm looking for an older jap master cylinder with a round plastic reservoir, any ideas ? Assuming 16mmx18mm ? Quote Link to comment Share on other sites More sharing options...
TLRS Posted April 1, 2020 Report Share Posted April 1, 2020 Ought to be a bore size on the m/c that should help the search? 12,5mm? Quote Link to comment Share on other sites More sharing options...
PBChris Posted April 1, 2020 Report Share Posted April 1, 2020 45 minutes ago, couchcommando said: Looking for a bike that uses 2 twin piston calipers along with an axial master cylinder with an external reservoir. Want to change the master cylinder on the VFR which is the honda one with a built in metal reservoir. Has to be axial not radial. Guess I'm looking for an older jap master cylinder with a round plastic reservoir, any ideas ? Assuming 16mmx18mm ? Bore size will be stamped on it - off the top of my head, something like a CBR400RR has similar sliding two-pot Nissins, but a remote reservoir m/c. It'll likely be a 14mm, 5/8 or possibly 1/2. All of which are pretty common across most Japanese manufacturers, shouldn't be any issue finding one. Quote Link to comment Share on other sites More sharing options...
simonb Posted April 1, 2020 Report Share Posted April 1, 2020 Not sure if this is any good to you,from a 97 Firestorm. Quote Link to comment Share on other sites More sharing options...
couchcommando Posted April 1, 2020 Author Report Share Posted April 1, 2020 Thanks guys some ideas Simon, thanks but firestorm has 4 pots 👍 Quote Link to comment Share on other sites More sharing options...
couchcommando Posted April 1, 2020 Author Report Share Posted April 1, 2020 BIt of digging looks like the VFR is 1/2”, an SV650 is 5/8” so would that give a nice improvement ? The discs are also up in size from standard 296 non floating to 310mm floating Quote Link to comment Share on other sites More sharing options...
dansp1 Posted April 1, 2020 Report Share Posted April 1, 2020 5/8 will just give you a soggy lever Quote Link to comment Share on other sites More sharing options...
coombehouse Posted April 4, 2020 Report Share Posted April 4, 2020 On 4/1/2020 at 8:00 PM, dansp1 said: 5/8 will just give you a soggy lever Surely the opposite. Bigger master cylinder = less travel, firmer lever, harder to pull. 1 Quote Link to comment Share on other sites More sharing options...
dansp1 Posted April 4, 2020 Report Share Posted April 4, 2020 you are right of course and i have lost the plot, im blaming lack of sleep 1 Quote Link to comment Share on other sites More sharing options...
couchcommando Posted April 11, 2020 Author Report Share Posted April 11, 2020 On 4/1/2020 at 6:06 PM, simonb said: Not sure if this is any good to you,from a 97 Firestorm. Change of plan means this could be of use to me, how much ? Quote Link to comment Share on other sites More sharing options...
simonb Posted April 11, 2020 Report Share Posted April 11, 2020 2 hours ago, couchcommando said: Change of plan means this could be of use to me, how much ? A tenner will do it to cover postage etc,if that's ok pm me your address and her indoors can take it to work with her on tuesday (she's a postie). 1 Quote Link to comment Share on other sites More sharing options...
