addiction269 Posted May 10, 2009 Report Share Posted May 10, 2009 just took the tank off to clean the filters out and its wet and stripping the paint of the the bottom edge of the tank that hides beneath the fairing. its possibly a loose hose connection so am gonna tighten everything up, but... in case.... has anyone used a tank sealer that they would recommend? and anything i should know about doing this cheers Link to comment Share on other sites More sharing options...
fredie Posted May 10, 2009 Report Share Posted May 10, 2009 about $20p for a sealent kit . 1 week for it to set . can u buy another tank from wreckers Link to comment Share on other sites More sharing options...
thefatman Posted May 10, 2009 Report Share Posted May 10, 2009 about $20p for a sealent kit . 1 week for it to set . can u buy another tank from wreckers This will work ok http://auto.frost.co.uk/frost/Por%2015%20Tank%20Sealer Link to comment Share on other sites More sharing options...
addiction269 Posted May 10, 2009 Author Report Share Posted May 10, 2009 cheers. cant get another tank, stoopid one off paint job..... Link to comment Share on other sites More sharing options...
Mr.Pigdog Posted May 10, 2009 Report Share Posted May 10, 2009 I've used a product called petseal quite a few times-usually because of heavy corrosion(sometimes so bad its leaking)has always worked well-just allow a couple of days for it to properly set and do it in summer when its reasonably warm! Just a quick edit to add that i chuck a chain or old nuts and bolts in the tank then shake it up to remove any loose parts first. Link to comment Share on other sites More sharing options...
Majik Posted May 10, 2009 Report Share Posted May 10, 2009 I've used a product called petseal quite a few times-usually because of heavy corrosion(sometimes so bad its leaking)has always worked well-just allow a couple of days for it to properly set and do it in summer when its reasonably warm! Just a quick edit to add that i chuck a chain or old nuts and bolts in the tank then shake it up to remove any loose parts first. +1 on this. Petseal has worked wonders for me in the past. Just prep right and don't rush it. I used bolts in the tank three or four times, and made darned sure I followed the instructions to the letter. Tank was rescued from the brink with no trouble at all. Smells nice too Link to comment Share on other sites More sharing options...
addiction269 Posted May 11, 2009 Author Report Share Posted May 11, 2009 yeah i saw this in fast bikes this month, seems like the best stuff then! thanks Link to comment Share on other sites More sharing options...
VeeTeeArr Posted May 11, 2009 Report Share Posted May 11, 2009 My Dad used glass fibre resin (just the resin) to repair the ally tank on his old Bond 875. He always had plenty about for body work repairs to the car. He mixed up enough to coat the complete inside of the tank, poured it inside then turned the tank until it coated it all over. Link to comment Share on other sites More sharing options...
gregtrx Posted May 12, 2009 Report Share Posted May 12, 2009 My Dad used glass fibre resin (just the resin) to repair the ally tank on his old Bond 875. He always had plenty about for body work repairs to the car. He mixed up enough to coat the complete inside of the tank, poured it inside then turned the tank until it coated it all over. That Bond is ace, is it the one with the hillman rear mounted engine and axle? I'd love a 3 wheeler at some point. Link to comment Share on other sites More sharing options...
lorenzo Posted May 12, 2009 Report Share Posted May 12, 2009 I'd love a 3 wheeler at some point. Take one of them off your transit, it's the only way you'll fit in a 3 wheeler, you had enough trouble in my mazda. Link to comment Share on other sites More sharing options...
VeeTeeArr Posted May 12, 2009 Report Share Posted May 12, 2009 That Bond is ace, is it the one with the hillman rear mounted engine and axle? I'd love a 3 wheeler at some point. Yes, Hillman Imp. 875cc Coventry Climax, all aluminium, 450 slant engine and transaxle. Lowdown weight over the back two wheels makes it much more stable[1]. Even so, you still need to get all your braking done in a straight line and accelerate through the corner. Also available as the Ranger Van [1] than the various Reliants, including the Bond Bug , which was made by Reliant, rebranded as Bond after they bought the Bond company. Link to comment Share on other sites More sharing options...
