hi and low speed damping
fastfox
Posted
Hi peeps.
Got a new bike. Its my first bike with both hi and low speed damping adjustment. (new R1)
Can someone exsplain what low speed and hi speed damping is and the effects i should exspect messing with it
Posted
Hi peeps.
Think of low speed damping as attitude control - for controlling the low speed movement of the shock - going over crests and into dips in the road. The high speed is for control/comfort over bumps. If you ride bumpy roads, reducing the high speed damping will make the ride more comfortable/less harsh.
BW
Posted
BW
Thanks Ben.
so basicly the hi speed damper is more or less what my R6 adjuster would of done.
Can you go more into the low speed side of things? Whats meant by "attitude controll"?
Posted
If it's any help , the high and low speed refer to the piston speed in the dampers , attitude control refers to how the bike pitches front to back or vice-versa
Posted
single compression adjsuter shocks tend to be of the low speed type anyway
Use Low speed compression for
Undulations
Controlling squat out of corners
Small ripples
Use high speed for
Big bumps (ie fast shock movement)
Pot holes etc
Two adjusters mean you can set it to be supple ashock for bumps, without it being too squidgy in the corners
Posted
Undulations
Small ripples
Use high speed for
Pot holes etc
Right, so low speed adjuster if i find the bike squats coming out of bends.
Hi speed if (as i do) find the bike is a bit choppy on bumpy roads.
To be honest, i`m finding the factory settings are more or less there appart from the ride is abit harsh on our crap roads.
Was planning to take a click or two out of the compression dampers front and rear
