thefatman Posted April 21, 2009 Report Posted April 21, 2009 Just thought i'd post this up to show a few people what to do if you perhaps put a little bend in your fork stanchion. You can buy replacement tubes and its not impossible to do. Also handy if your swapping over from normal brakes to radial brakes if making a mix of fork bits. I've only ever done mountain bike forks before but looking at them theres no difference so here we go. The mounts are held on with super strength loctite, so heat will help. Some are threaded on to the tube, possibly with a grubscrew to stop them turning. Others are simply pushed on, like the ones here. First you need to clamp the fork tube in the vice to stop it turning. Soft jaws otherwise you'll mark the tube which will ruin the seals. Even better would be an alloy clamp, split in half to go around each side of the leg. Next a bar the same size as the axle, you could use the axle if its fairly solid but modern ones are a bit light for it so a bar is better. Last is heat to break the bond of the loctite. A heat gun will work perfectly for this, unless yours is broken and you only have gas to hand. A very simple process - Remove grubscrew, heat up the casting, unscrew (may need a small extension bar). Job done. Now you can replace your bent fork tube, send it of to have it rechromed or nitrided, get the castings powder coated, or fit those flash radial brake bottoms you've bought for your forks. There we go, all finished
lorenzo Posted April 22, 2009 Report Posted April 22, 2009 Nice write up. Is that sambuca in the top of the fork leg?
thundercat rider Posted April 22, 2009 Report Posted April 22, 2009 Great how-to. I got some bent yzf 750 forks waiting to be repaired.
heds954 Posted April 22, 2009 Report Posted April 22, 2009 Nice one theFatman, another masterclass explained for the ordinary dimwit like me ...just had a thought, GP doesn't read these does he, no, but if he did, he wouldn't, would he?
will#224 Posted April 22, 2009 Report Posted April 22, 2009 Excellent, was there no adjuster for compression on that leg? if so what did you have to do with that?
gregtrx Posted April 22, 2009 Report Posted April 22, 2009 Excellent, was there no adjuster for compression on that leg? if so what did you have to do with that? Wouldn't this come out when you took the cartridge out?
thefatman Posted April 22, 2009 Author Report Posted April 22, 2009 Wouldn't this come out when you took the cartridge out? Unscrew it first!
rich7/12 Posted April 27, 2009 Report Posted April 27, 2009 That's awesome - and great timing - I might need to do this. Just a couple of questions... Guessing you need to drop the fork oil out first? When putting back together I'm guessing its important to replace the loctite-type glue with something. Would loctite do it? Thanks in advance for your help, Rich
thefatman Posted April 27, 2009 Author Report Posted April 27, 2009 Guessing you need to drop the fork oil out first? Would loctite do it? Yes out with the oil, red loctite should be fine.
rich7/12 Posted April 27, 2009 Report Posted April 27, 2009 Yes out with the oil, red loctite should be fine. nice one - thanks for that!
thundercat rider Posted June 1, 2009 Report Posted June 1, 2009 Eh, how do you put a fork tube back in the fork bottom btw? Don't kayaba/showa use some special glue?
thefatman Posted June 2, 2009 Author Report Posted June 2, 2009 Eh, how do you put a fork tube back in the fork bottom btw? Don't kayaba/showa use some special glue? If its a screw on bottom then screw it back on, push fit then use a press. Loctite will do, heavy duty stuff not threadlock.
pbc0 Posted January 27, 2014 Report Posted January 27, 2014 Excellent post.I now won't be scared of taking this job on myself now.Thanks
