riversbikes Posted April 20, 2009 Report Posted April 20, 2009 Based on the advice found here, methinks a 16mm master is the way to go. I've been hearing online rumours (it must be true, it was on the internet) that some late model 600s come with a 16mm radial master cylinder... can anyone confirm this? Some say that a newer (07 and up) zx6r has a 16mm nissin; even the R1 apparently comes with same. Input?
tootall Posted April 20, 2009 Report Posted April 20, 2009 Based on the advice found here, methinks a 16mm master is the way to go. I've been hearing online rumours (it must be true, it was on the internet) that some late model 600s come with a 16mm radial master cylinder... can anyone confirm this? Some say that a newer (07 and up) zx6r has a 16mm nissin; even the R1 apparently comes with same. Input? Pretty sure you're right. '05 onward R6 has a 16mm radial m/cyl too.
