Devon Posted April 11, 2009 Report Share Posted April 11, 2009 i have a aprilia rs125 and have discovered that there is a large amount of scoring on the barrel, my question is, is it a good idea to just remove the oil injector and run the bike on a premix, will this make any difference to the running of the bike. i understand that i will have problems when visiting the petrol station etc but thats no problem . so what do you think? Link to comment Share on other sites More sharing options...
spacemonkey Posted April 11, 2009 Report Share Posted April 11, 2009 i have a aprilia rs125 and have discovered that there is a large amount of scoring on the barrel, my question is, is it a good idea to just remove the oil injector and run the bike on a premix, will this make any difference to the running of the bike. i understand that i will have problems when visiting the petrol station etc but thats no problem . so what do you think? You will also have to rejet the bike as it will start to run leaner. (You will get less fuel for a given jet size since some of the fluid is oil.) I would avoid doing this. Check your oil pump is working and if not then a replacement will be easily found on Feebay. Link to comment Share on other sites More sharing options...
Powerwheelie Posted April 12, 2009 Report Share Posted April 12, 2009 I run pre-mix but my bike is a fun bike, Makes it alot more smokier and yeah you have to up-jet, Whats the purpose of your bike ? Link to comment Share on other sites More sharing options...
si.likes.guiness Posted April 14, 2009 Report Share Posted April 14, 2009 if its a track bike premix but if its for the road i wouldnt bother mate leave the pump on Link to comment Share on other sites More sharing options...
