ste996 Posted August 19, 2015 Report Share Posted August 19, 2015 The rev counter needle on the 7r twitches around the 10,500 rpm in any gear,3rd onwards is when I notice it. Sometimes it's really obvious and I can feel the bike hesitate/stutter. I have a little clip of it doing it today, only slightly but it does this 90% of the time that I know of. If caught (seen with my own eyes) at the right time it's quite severe bouncing between 10 & 11,000 revs mark. UsIri3BLh9c Standard airbox, filter and exhaust. A quick look over nothing seemed out of order, main earth point clean and all connector blocks in good order, plugs all ok, coils swapped as I have a spare set just to see and no change. Carbs had a good going over aswell with correct jets etc fitted. Link to comment Share on other sites More sharing options...
nzknut Posted August 19, 2015 Report Share Posted August 19, 2015 Probably dry solder in the back of the clocks EDIT - just read it again, if you've swapped the coils, what about the crank trigger being loose? How is the battery? Link to comment Share on other sites More sharing options...
Mahatma Posted August 19, 2015 Report Share Posted August 19, 2015 Is it me or did that bike sound sour?More competent lads will get on the case soon Link to comment Share on other sites More sharing options...
ste996 Posted August 19, 2015 Author Report Share Posted August 19, 2015 Does sound abit off to me to on playback. I put it down to much wind noise for the mic on the camera. Link to comment Share on other sites More sharing options...
