bogman Posted October 23, 2014 Report Share Posted October 23, 2014 i have some rgv cylinder studs to remove,got 2 out using the 2 nut method,others won,t budge. i don,t posess an extractor,any other methods to remove them/? Link to comment Share on other sites More sharing options...
svingel Posted October 24, 2014 Report Share Posted October 24, 2014 Heat the cases, and use moderately persuasive impact force(twat 'em wi' an 'ammer), on the tops, to break the corrosion on the threads. Soaked them in WD40? Link to comment Share on other sites More sharing options...
kja.busa Posted October 24, 2014 Report Share Posted October 24, 2014 If you get really stuck I have an extractor you can borrow, where are you in Lincs? Link to comment Share on other sites More sharing options...
John21 Posted October 24, 2014 Report Share Posted October 24, 2014 My extractors are far worse than the two bolts method. My 2 cents Link to comment Share on other sites More sharing options...
jaycee Posted October 24, 2014 Report Share Posted October 24, 2014 Plusgas, its the best penetrating fluid ever. Link to comment Share on other sites More sharing options...
Wildbill Posted October 24, 2014 Report Share Posted October 24, 2014 "Plusgas, its the best penetrating fluid ever."Vodka and Tonic or pints of Slalom D lager has worked pretty good for me in the past Link to comment Share on other sites More sharing options...
bogman Posted October 25, 2014 Author Report Share Posted October 25, 2014 thanks for the replies lads eventually sorted it this am with a combo of plusgas/hammer/2 nuts Link to comment Share on other sites More sharing options...
Jenny Pryde Posted October 25, 2014 Report Share Posted October 25, 2014 thanks for the replies lads eventually sorted it this am with a combo of plusgas/hammer/2 nuts Blood pressure returned to normal? ;-) Link to comment Share on other sites More sharing options...
