hipringle Posted February 23, 2009 Report Share Posted February 23, 2009 Hi, my rad has slight pitting in one area & could do with something like a spot weld to keep it right. Its not leaking but looks a bit thin where its pitted, would a soldering iron with any special solder fix it or would I be able to use some kind of ali solder you heat up & can buy at b & q, any help appriciated. dont want to resort to a huge lump of chemical metal just yet...... Link to comment Share on other sites More sharing options...
kwakbiker Posted February 23, 2009 Report Share Posted February 23, 2009 I have used some ali rod in the past to do a fix on my 9r, worked fine but then my stepdad is a bit nifty with stuff like that Could just pop it along to a rad repairers, should be a cheap fix Link to comment Share on other sites More sharing options...
lorenzo Posted February 25, 2009 Report Share Posted February 25, 2009 If it's just thin, then a smear of chemical metal is what I'd be doing... Who me, botch? Never... Link to comment Share on other sites More sharing options...
hipringle Posted February 25, 2009 Author Report Share Posted February 25, 2009 normally mate I,d chemical metal too but this is 851 ducati territory & needs a proper bodge. I,ve ordered some low heat ali rods which weld at 360c but will try on another thin bit of ali first just in case,...... cheers chaps. Link to comment Share on other sites More sharing options...
