Brake fluid hose?
bigkev
Morning all two questions, first off I oredered some H.R.C. rear brake fluid hose/reservoir from Honda a while ago after some one kindly posted up the part numbers here but I have lost all the numbers so if anybody has them could they stick them up or PM me please.Secondly I have bought a pair of Brembo master cylinders but they have a much smaller diameter fluid supply fitting, anyone know where I can get some hose for this?
Thanks
Thanks
You can use food and checmical rated hose that is non-hydroscopic. In the US I use product called Tygon 2075, it is better than the HRC 'pipe' in that the Tygon 2075 remains flexible and does not harden or discolor (IMExperience). As for the sizing, Tygon 2075 comes in a variety of sizes, choose the one you need. If you simply want the HRC kit again, try tygaperformance.com.
Thanks
HTH
HTH
Don't buy the HRC hose kit, I have one and it's really not intended for road use. Firstly, the hose hardens and discolours over time (3 months time will ruin it), you will find it hard to do up to the rear master inlet (I/D of the hose is much bigger than O/D of the master inlet) and the hose cap isn't vented, so it creates a vacuum when fluid is used, holding the pistons back.
A CRF style integrated resovoir (with a vented cap) is a much better solution
Take a look at
http://www.kc-engineering.de/ they do a integrated resovoir which is really neat (page 4 under Flüssigkeitsbehälter)
Ronni
Take a look at
Ronni
I have been using an official HRC and now a HRC 'style' (using the plug, but with Tygon 2075 hose) going on 2 years exclusively on the road, no worries at all.
