daytona63 Posted February 8, 2009 Report Share Posted February 8, 2009 Thought i would wheel the track bike out this morning and start it up. It started no problem but there is a continous clicking noise coming from somewhere on the right hand side. It does this when the bike is stationery and even with the engine off.. but the ignition on obviously. Something electrical but what? Could it be the fuel pump? It's a 1999 CBR600Fx by the way. Link to comment Share on other sites More sharing options...
daytona63 Posted February 9, 2009 Author Report Share Posted February 9, 2009 Not sure...i would doubt it but i'll have another look. It certainly didn't do it the last time i started it and it didn't seem to effect the running of the bike. Link to comment Share on other sites More sharing options...
lorenzo Posted February 9, 2009 Report Share Posted February 9, 2009 It's obviously electrical as it does it without the engine running. Try pulling fuses out 1 at a time until it stops, that'll narrow your search down a bit. Or you could just have a bomb on board? Link to comment Share on other sites More sharing options...
daytona63 Posted February 9, 2009 Author Report Share Posted February 9, 2009 No cos it did it from start up, Zak. I can turn the ignition on (i.e the killswitch) and it makes the noise whther i start it or not. I did wonder whether it had anything to do with the battery being a bit low on power! Link to comment Share on other sites More sharing options...
thorlz Posted February 9, 2009 Report Share Posted February 9, 2009 like people say, sounds like a relay, maybe starter as stated pop out the fuses one at a time to narrow it down to which circuit/relay or stuck/shorted switch trying to bring in a relay Link to comment Share on other sites More sharing options...
kawafookin636 Posted February 9, 2009 Report Share Posted February 9, 2009 It started no problem but there is a continous clicking noise coming from somewhere on the right hand side. It does this when the bike is stationery and even with the engine off.. but the ignition on obviously. Something electrical but what? Hi. I know you said it was a 'clicking', would it be like a 'brrrrrrrring' clicking noise? ( yes I know that sounds weird! ) Just that my wifes' FX does the same thing, but only for a second or so. If it is, let me know as I'll be in the garage tomorrow and don't mind looking where it's coming from, and how to make it go away! Link to comment Share on other sites More sharing options...
kawafookin636 Posted February 9, 2009 Report Share Posted February 9, 2009 That should have read 'Brrrrrrrr' ing noise ( amended due to idiot ie me ) Link to comment Share on other sites More sharing options...
daytona63 Posted February 9, 2009 Author Report Share Posted February 9, 2009 Yes it is that type of noise. Like a clock winding itself down very quickly. Link to comment Share on other sites More sharing options...
kawafookin636 Posted February 9, 2009 Report Share Posted February 9, 2009 I shall have a poke around then tomorrow, try and replicate it, and let you know . . Link to comment Share on other sites More sharing options...
Mr.Pigdog Posted February 9, 2009 Report Share Posted February 9, 2009 Fuel pumps often do that until theyre up to pressure Link to comment Share on other sites More sharing options...
kawafookin636 Posted February 10, 2009 Report Share Posted February 10, 2009 Right, had a poke around with the wifes' FX today. Ignition on, 1 to 2 second 'brrrr' ing noise from fuel pump and also heard a 'click' from one of the relays on the right hand side of the subframe. So, seat off and did it again. narrowed it down to the ' fuel pump transfer relay ' ( largest of the 4 relays there ) Had a look in the manual and there's loads of spiel on what to do to fault check it, mainly to do with fuses and con checking with a multimeter. If this helps, the battery is in good condition and was only charged about a week ago. Have noticed when it has been stood for longer the noise does go on for a few seconds longer Hope that helps! Link to comment Share on other sites More sharing options...
