Jamie Posted February 8, 2009 Report Share Posted February 8, 2009 Hi, Doe anybody have any ideas how to remove the clutch basket from My 2004 R6? Pressure plate and centre removed easily enough but the basket is attached to a gear wheel which is too big to come off the splined shaft and clear the cases. Does the clutch basket seperate from this gear or do you have to separate the cases in order to remove the whole asembly? Rather usefully the yamaha manual covers every operation until this point!!!!!! Thanks in advance for your help, jamie Link to comment Share on other sites More sharing options...
Coose Posted February 8, 2009 Report Share Posted February 8, 2009 There's probably a steel bush in the centre of the clutch basket that you can pull out once you have removed the clutch centre. This should give you a bit more movement on the basket to be able to wiggle it out. Don't, under any circumstances try to remove the basket from the gear! Link to comment Share on other sites More sharing options...
Jamie Posted February 8, 2009 Author Report Share Posted February 8, 2009 Cheers Coose, Yep having had a look with a clear head it's become embarasingly obvious!!! Thanks for your extremely quick response mate i owe you one! Jamie Link to comment Share on other sites More sharing options...
