2639 Posted February 5, 2009 Report Share Posted February 5, 2009 As above, have gearbox and other bother with my 7/11. Might be able to get a complete y plate Bandit 6 eng carbs electrics. Will it fit easily. As in straight in, only spanners required. (i know anything will fit anything if I try hard enough, but I don't have the time, equipment or will for messing about this time) Its a 750 L ( I think, USD forked model, 17 rims 180 back) Don't whinge about it not being a 'big' engine - I don't care Just need transport asap. All info much appreciated. Link to comment Share on other sites More sharing options...
Liamo Posted February 5, 2009 Report Share Posted February 5, 2009 it should be a handy enough swap. I think you run into trouble putting Gixxer engines into bandits as the bigger engines have deeper sumps which can cause clearance issues with the headers. If you had the Bandit header pipes, I'd say it'd be a very handy job. BTW, I'm not 100% sure of any of that info. Link to comment Share on other sites More sharing options...
originalracingsnake Posted February 5, 2009 Report Share Posted February 5, 2009 Agree, it should slide in easy. Confirm with these chaps though, www.oldskoolsuzuki.org Link to comment Share on other sites More sharing options...
wavydavy Posted February 5, 2009 Report Share Posted February 5, 2009 Wasn't there a US model GSXR600, using the cradle frame from the 750 with what later became the Bandit 600 motor in it? Assuming that the frame motor are the ones I;m thinking of, it should be a doddle (if you know what you're doing, like...) Dave Link to comment Share on other sites More sharing options...
banoffee Posted February 5, 2009 Report Share Posted February 5, 2009 should be a straightforward swap as quite a few have fitted oilcooled 750 lumps to 600 bandits... http://oldskoolsuzuki.info Wasn't there a US model GSXR600, using the cradle frame from the 750 with what later became the Bandit 600 motor in it? Assuming that the frame motor are the ones I;m thinking of, it should be a doddle (if you know what you're doing, like...) Dave there was a watercooled 600, dont think there was an oilcoole one. not a simple swap between the two types of motor (oil and water) but can be done with some faffing Link to comment Share on other sites More sharing options...
fran9r Posted February 5, 2009 Report Share Posted February 5, 2009 There was a GSXR 600, not a UK model though. Same 750 lump with smaller pistons. The bandit engine is only a GSXF engine, so it should go in. A 750 top end will go straight on too. I know this as I won the old (shh) Superbike magazines' GSX 600 F, with had a 750 top end, bored to 907 cc and producing 116 brake. It could have had a lot more with bigger carbs. This was somewhat unimportant though, as the chassis could handle 80. It would have made a good shitefighter with a GSXR frame though. Link to comment Share on other sites More sharing options...
ronenige Posted February 5, 2009 Report Share Posted February 5, 2009 have a look at the relevant parts on here , http://www.alpha-sports.com/suzuki_parts.htm the crankcases look very similar , it may give you an indication of what spacers , bolts etc you will need Link to comment Share on other sites More sharing options...
bezzer Posted February 5, 2009 Report Share Posted February 5, 2009 It'll drop straight in....but the 1100 has an M12 lower rear mount, the 750 and B6 has an M10 one must have either the frame hole enlarged or a sleeve/bush at the moment, just got to alter it back to fit the B6 solidly. Link to comment Share on other sites More sharing options...
dizzyr1 Posted February 6, 2009 Report Share Posted February 6, 2009 Best to lock up me garage then!!!!!! i dont have the balls to ask di if you spoke to her on this subject, cos it will remind her to push said offending bandit out, ps none of my bikes are on the organ donor list! Link to comment Share on other sites More sharing options...
2639 Posted February 6, 2009 Author Report Share Posted February 6, 2009 I'm gonna gob the rattly fuckin thing back together and throw some sawdust in the thing to shut it up Dizzy's shed 02 03 09 Link to comment Share on other sites More sharing options...
