Swapping swingarms
drunkn munky
Whats involved in getting the correct chain allingment when swapping swingarms,
its on a mk1 cagiva mito and was thinking rgv vj22 swinger as it has a 3 spoke wheel and would match the ducati front end
As long as you have the wheel centrally aligned on the bike you can have a machine shop take material off your sprocket carrier to help get your chain alignment correct. You used to be able to get offset sprockets too, front and rear to help. Make sure your chain doesn't chew the tyre mind...
