CBR600FS front master cylinder bore size
BenW
Posted
Anybody know the bore size of the front brake master cylinder for a 1995 CBR600F steelie?
I'd look on the bike tonight but, typically, I need to know today.
Thanks in advance
BW
Posted
Thanks in advance
BW
its 1/2 inch mate, if youre getting a new one of a breakers, then a early blade or 03-06 600rr one is basically the same but 5/8ths .
Most of the steel frame racers use this mod cos it gives more power and feel.
hope this helps
Posted
hope this helps
Thanks chap. 1/2" is 12.7mm and the 5/8" is 15.8mm or so. That works out nicely. The 16mm bore I'm looking at should be fine.
BW
Posted
BW
Will be perfect.
