tootall Posted August 13, 2012 Report Share Posted August 13, 2012 Righto need some new, good quality, accurate and reliable guages. Any recommendations? Are the carbtunes any good for everyday use? Any particular makes/models of dial guages I should get/avoid? Link to comment Share on other sites More sharing options...
VanWinkle Posted August 13, 2012 Report Share Posted August 13, 2012 Had my carbtune guages for about 7 years now. Not used them on an every day basis but i reckon ive had my moneys worth out of them. Link to comment Share on other sites More sharing options...
lorenzo Posted August 13, 2012 Report Share Posted August 13, 2012 I've read loads of people swear by carbtunes, but a few people have checked the accuracy of them by using a t-peice so you can compare the one vacuum source on 2 dials and they've always been off, hence your syncing has never been spot on. I have an electronic little thing which I can't remember the name of at all, but it's bang on, the only downside is it's only got 2 inputs so you're always just using 1 inlet as a datum to do the others by. Link to comment Share on other sites More sharing options...
Gregorious77 Posted August 13, 2012 Report Share Posted August 13, 2012 I use 4 of these http://www.cromwell.co.uk/index.php?q=0&p=viewproduct&i=KEN5031140K Link to comment Share on other sites More sharing options...
Fatbloke Posted August 14, 2012 Report Share Posted August 14, 2012 I use carbtunes and so far am happy with them. If they are in regular use the plastic adaptors will wear out but brass ones are available. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted August 15, 2012 Report Share Posted August 15, 2012 Air flow meter ? then you don't need to put vacuum pipes on Link to comment Share on other sites More sharing options...
Toseland's Eyebrows Posted August 15, 2012 Report Share Posted August 15, 2012 I might get me some of those brass adaptors, the plastic ones were a bitch to get in to the 3rd and 4th cylinders, they kept cross threading as they were obscured by coolant hoses Both bikes I've used the carbtune on have run a lot better afterwards, I'd recommend them. Link to comment Share on other sites More sharing options...
hotballs Posted August 29, 2012 Report Share Posted August 29, 2012 i bought the davida ones and reckon they are great Link to comment Share on other sites More sharing options...
