Zx7R Oil Pump Question
speedy sie
i have found a way to got direct drive on to the oil pump off the clutch but i will lose 15% on the gearing this way,so pump will spin 15% less each revolution,but to compensate for this i will blank of the oil feed that fed the top of the chain, that use to dive the oil pump and geney,so will this be ok???
the rear chain drive cog of the clutch basket will fit the pump with some welding and machining and make the oil pump gear driven.
engine is a race bike engine
