roastdinajima Posted January 15, 2009 Report Posted January 15, 2009 I've just brought a '00 zx6r track bike for next to nowt with a mate but its a non runner previous owner did a track day about six months ago and shortly afterwards he was unable to start it. He thinks its an electrical problem relating to the coil packs but before we start checking every wire and connection on the thing are there any particular faults or weakness's we should look out for specific to 6r's or in general (apart from it being a kwakka) Thanks in advance.
roastdinajima Posted January 15, 2009 Author Report Posted January 15, 2009 I won't pick the bike up till next week, it turns over just fine. When i get it back we'll all the check all the simple stuff spark,fuel etc i think the previous owner may have been a bit ham fisted and messed around with wires that didn't need messing with the ignition barrel and kill switch look a bit of a bodge
Mr.Pigdog Posted January 15, 2009 Report Posted January 15, 2009 I don't know of any inherant weaknesses on this model-engines are pretty strong.I have come across one that water had managed to track down through the junction box and shorted out the circuit board(on the back,out of sight)which stopped it running.Gonna have to start by checking for a spark arent you-probably is electric.Good luck
buster Posted January 15, 2009 Report Posted January 15, 2009 After you've checked the obvious stuff and if its not sorted it try out this link http://www.ninja6zone.com/forums/homepage.php Loads of people with good info. I've got the J1 model and they are rock solid in my opinion and forum members agree too, no common faults.
roastdinajima Posted February 15, 2009 Author Report Posted February 15, 2009 She lives!! we spent an hour or so today and got it it running which was nice. The fault was in the abortion of wiring the last owner messed around with, The original ignition switch had been removed to allow the fittment of a steering damper which goes from the left hand fork to a bolt welded onto the clock mounting bracket i think any decent tankslapper would snap this home made bracket straight away, so we removed this and an fitted ignition barrel and switch from the box of spares we got with the bike and were rewarded with lots of noise and some flames from the hindle pipe WOO HOO!!
stretch Posted February 17, 2009 Report Posted February 17, 2009 that guy bolted the steering damper to the clocks?!?! i would start methodically looking over this whole bike if i were you, make sure he didn't gas in the coolant tank, etc.
roastdinajima Posted February 18, 2009 Author Report Posted February 18, 2009 Not to the clocks themselves but to the bracket the clock bracket mounts to if you see what i mean.
kwakbiker Posted February 18, 2009 Report Posted February 18, 2009 Glad its fixed but still didnt sound like a great mount point(used to have a G2 6r)
