coppersaucepipe Posted January 14, 2009 Report Share Posted January 14, 2009 Does anybody know what front ends will just bolt on to a CBX550 (other than another cbx550 front end)? My mate is looking to dump his over engineered cbx front end with seized enclosed discs and naff antidive and fit a more conventional set up, preferably with a 17" front wheel. Ta Link to comment Share on other sites More sharing options...
kinkyfreestyler Posted January 14, 2009 Report Share Posted January 14, 2009 look and see which headbearings fit then cross match to other bikes ! then all you have to do is find out the lenght of the steerer tube of the forks that take the same bearings It worked for me now I have a zxr 400 h1 front fork set up on my zephyr 550 .just had to drill the top yoke to mount the bars ! hope this gives you a start point ? Link to comment Share on other sites More sharing options...
kja.busa Posted January 16, 2009 Report Share Posted January 16, 2009 look and see which headbearings fit then cross match to other bikes ! then all you have to do is find out the lenght of the steerer tube of the forks that take the same bearings It worked for me now I have a zxr 400 h1 front fork set up on my zephyr 550 .just had to drill the top yoke to mount the bars ! hope this gives you a start point ? Bandit front ends can usually be had for the right sort of money, a good 600 front end should be the best option I reckin. Link to comment Share on other sites More sharing options...
lorenzo Posted January 18, 2009 Report Share Posted January 18, 2009 I bought a full gsxf front end and back wheel too for less than £70 a few months back. Just shop about a bit, loads of things can be made to fit. Measure the uncomressed length and so long as it's not much more than an inch shorter you'll be OK, I'm sure. Link to comment Share on other sites More sharing options...
