stormtrooper Posted March 5, 2012 Report Share Posted March 5, 2012 right here goes im bringing back to life a mates 97 600 srad for him as its been off the road for some time so going to be doing some work on it for him fork seals need done so can anyone tell me how much oil and what grade oil i would need 10w ? also rear shock is fooked so got a low milage one on its way can anyone tell me a good suspension settings for fast road for someone 15stone thanks in advance Link to comment Share on other sites More sharing options...
stormtrooper Posted March 7, 2012 Author Report Share Posted March 7, 2012 Anyone ?? Anyone ?? Link to comment Share on other sites More sharing options...
BudgetBoy Posted March 7, 2012 Report Share Posted March 7, 2012 ok 110mm air gap of 10w oil Link to comment Share on other sites More sharing options...
BudgetBoy Posted March 7, 2012 Report Share Posted March 7, 2012 can anyone tell me a good suspension settings for fast road for someone 15stone First you will need to uprate your standard fork internals (springs) as these are only .762kg/mm You either want .95kg/mm or 1.0gk/mm springs based on your weight. Your rear shock is also wrong as its 6.4kg/mm and you want 7.625kg/mm So you want a 7.6kg/mm spring. Once you have done this you can then renew all the oils in the shocks and set up your sag.Set the rebound,comp etc to factory setting and then set your sag. Rider sag & Static sag.. Then fine tune it to your needs after some ride outs. Simples. Hope that helps. Link to comment Share on other sites More sharing options...
stormtrooper Posted March 7, 2012 Author Report Share Posted March 7, 2012 thakyou just what i was looking for Link to comment Share on other sites More sharing options...
