B@W Posted January 6, 2009 Report Share Posted January 6, 2009 I can't get my head around which tyres fit which wheel, for example what tyre would fit a 5.5'' rim? My simple maths (5.5'' x 25.4mm) says 140 section tyre but that can't be right. Mark Link to comment Share on other sites More sharing options...
Liamo Posted January 6, 2009 Report Share Posted January 6, 2009 The angle of the dangle is indirectly proportional to the heat of the meat. HTH. Link to comment Share on other sites More sharing options...
David W Posted January 6, 2009 Report Share Posted January 6, 2009 No it's not right. 5.5" rim typically uses a 180. 6" uses 190. Link to comment Share on other sites More sharing options...
chrisexup Posted January 6, 2009 Report Share Posted January 6, 2009 http://www.naughtyboymotorracing.com/articles/tiresizes.jpg Link to comment Share on other sites More sharing options...
2 smokes 4 ever Posted January 6, 2009 Report Share Posted January 6, 2009 The angle of the dangle is indirectly proportional to the heat of the meat. HTH. I'm sorry but you are incorrect The angle of dangle = The Throb of the knob, when the urge is constant this is a rough guide for tyre width Vs rim width Its best to choose a rim width in the middle of the range As the profile % goes down, so the choice of rim sizes for a given tyre width decreases Each tyre manufacturer can be different though, and the recommended rim widths for a given tyre (as it can vary between different tyres from the same manufacturer) is usually somewhere on their website Link to comment Share on other sites More sharing options...
Liamo Posted January 7, 2009 Report Share Posted January 7, 2009 I'm sorry but you are incorrect The angle of dangle = The Throb of the knob, when the urge is constant You see we're both right. If the AoD = TotK AND Aod = 1/HotM THEN 1/hotm = TotK QED Link to comment Share on other sites More sharing options...
lorenzo Posted January 7, 2009 Report Share Posted January 7, 2009 No, if the HotM was inversely opposite to the AoD, as you've equated above Liamo then it would mean that you get an increase in throb as heat reduces, and that, as I'm sure you know, is incorrect. If you are unsure, take a look on google. May i suggest using keywords like 'busty' and a small thermometer. Link to comment Share on other sites More sharing options...
Liamo Posted January 7, 2009 Report Share Posted January 7, 2009 No, if the HotM was inversely opposite to the AoD, as you've equated above Liamo then it would mean that you get an increase in throb as heat reduces, and that, as I'm sure you know, is incorrect. If you are unsure, take a look on google. May i suggest using keywords like 'busty' and a small thermometer. er ... boobies? Link to comment Share on other sites More sharing options...
B@W Posted January 7, 2009 Author Report Share Posted January 7, 2009 Thanks people, especially for the 'constructive' comments Link to comment Share on other sites More sharing options...
