How Can I Remove Stock Ignition To Put A Stop Start Switch On???
addiction269
how if poss, can i remove the key ignition for a simple push start switch, its only for a track bike so security isnt as much of an issue? any help appreciated!
What bike is it for would be a help
Wire it into a lovely Honda switch like this ;)
It's very easy if there is no factory fitted immobiliser system on your bike. If there is, then you'll still need to keep the chip/key attached to the transponder ring around the ignition barrel and fit this somewhere safe on the bike. If you don't have this and your bike is a simple turn the key, then at the bottom of the barrel you'll have 2 wires which you can wire into a switch like this ^
HTH
T
a toggle switch sounds cool - but not as cool as a big red button with fire on lol its a zx7r so by the sounds of it can be easily moved to a switch. cheers for the help
