Expansion Chamber Design
Adam
I've been rebuilding a bike for my girlfriend, a Peugeot 103. I'm trying to fab a spannie for it and I was wondering if any of you with a bit of software would mind dropping the numbers in for me.
Exhaust Duration = 147 degrees.
Engine Speed = 6500 rpm
Exhaust Flange = 21mm dia & 35mm from piston face.
Cheers
Adam
exhaust port area,transfer duration, rod length, bore and stroke , compression ratio, gearbox ratios(if any)?????
A 6500 rpm peak pipe will be ablout 1300mm long
Ex port area = 300mmsq
Transfer duration = 115 degrees
Rod length = 80mm
Bore = 40mm
Stroke = 40mm
Comp ratio = 8:1
No gears.
Cheers
OK this will rev a LOT harder
23-23(31)
23-36(205)
36-50(80)
50-64.5(66)
64.5-92(90)
92-92(77)
92-83(36)
83-17(143)
All dimensions in mm lengths in brackets.HTH
23-23(31)
23-36(205)
36-50(80)
50-64.5(66)
64.5-92(90)
92-92(77)
92-83(36)
83-17(143)
Thanks for that, it's quite a bit shorter than 1300mm!
How do you mean a LOT harder?
Looks proper though, thanks again.
