YAMMAFAN Posted September 11, 2011 Report Share Posted September 11, 2011 I'm currently in the process of changing the front sprocket on my 2005 fireblade, and referring to my trusty Haynes manual it says I need to remove the clutch release cylinder (slave cylinder) to access it. The job looks straight forward enough but Mr Haynes states that I should use a new gasket. Problem is I’ve looked all over the net and can’t seem to find one! I’m no longer local to the Honda dealer I bought the bike from (or any Honda dealer) so I was wondering if anyone knows where I can find one or if I even need to bother changing it? Any advice much appreciated. Link to comment Share on other sites More sharing options...
stupid luke Posted September 11, 2011 Report Share Posted September 11, 2011 Cant be of much help I am afraid. I got to the same bit, you quoted in the Haynes manual and decided +3t on the rear was a better way to go. It was possible with the standard chain (just) but shortened the wheelbase somewhat. For my wet wheels I stuck with +2t rear (standard gearing on 06/07) and tightened the chain adjusters. Link to comment Share on other sites More sharing options...
YAMMAFAN Posted September 12, 2011 Author Report Share Posted September 12, 2011 I'm changing the rear to a 42 (+2) but my chain has a couple of tight spots so wanted to change that as well, and hence decided to change the front sprocket as well. Hopefully going up 2 on the back sprocket will be worth it! Link to comment Share on other sites More sharing options...
Gregorious77 Posted September 12, 2011 Report Share Posted September 12, 2011 http://www.davidsilverspares.co.uk/ Link to comment Share on other sites More sharing options...
