kaighn80 Posted January 5, 2011 Report Share Posted January 5, 2011 found this and it helps a lot with changing wheel/tyre combo's and sprocket changes. http://www.gearingcommander.com Link to comment Share on other sites More sharing options...
wazrs257 Posted January 6, 2011 Report Share Posted January 6, 2011 Just calculated the results for my RS257 & it seems to work out about right. Link to comment Share on other sites More sharing options...
Gregorious77 Posted January 7, 2011 Report Share Posted January 7, 2011 I have that bookmarked and it is well handy. Link to comment Share on other sites More sharing options...
morepower Posted January 21, 2011 Report Share Posted January 21, 2011 Used it for the P3 Suzuki project.. Got the site owner to alter his RPM scale as it would not want to show RPM higher than peak power... But told him the motor was tuned and after some tweaking it now is great for even tuned motors.. It got the top speed of the GSXR600 spot on when we looked at the GPS and calibrated speedo healer. 174MPH on the calculator, gps and the speedo healer! Link to comment Share on other sites More sharing options...
Acid Posted July 29, 2011 Report Share Posted July 29, 2011 why is this not a sticky !!!! sm rims on my cr500 and 15 38 gearing = 90 topend !!! Link to comment Share on other sites More sharing options...
wazrs257 Posted July 30, 2011 Report Share Posted July 30, 2011 why is this not a sticky !!!! sm rims on my cr500 and 15 38 gearing = 90 topend !!! Can't remember the gearing off the top of my head, but in the olden days, John Robinsons CR500 did 115! Link to comment Share on other sites More sharing options...
fontyyy Posted August 2, 2011 Report Share Posted August 2, 2011 Theres a fault in there somewhere, if you use different Max RPM values they don't get shown correctly on the shift speed sub graphs. All three graphs use the highest red line set in any of the setups; This yields for "custom" which is correct, but for "current" which is wrong (gear changes are still happening at 12280 when they should be at 11440), it's the same on the stock graph too It should look like this Shame as the site is a good idea. Link to comment Share on other sites More sharing options...
wazrs257 Posted November 1, 2011 Report Share Posted November 1, 2011 Does anyone have the stand alone version of this software? The site doesn't seem to be working properly at the moment (or is it just me?) so I was thinking of 'buying' the stand alone version. Link to comment Share on other sites More sharing options...
kaighn80 Posted November 3, 2011 Author Report Share Posted November 3, 2011 works for me although it did just tell me i should be able to hit 160 on an fzr400 with a 600 lump fitted (loaded the data for the 600 then changed the sprockets and chain to what the 400 already had) Link to comment Share on other sites More sharing options...
