LLCOOLJ Posted October 19, 2010 Report Share Posted October 19, 2010 Hi All, Maybe there are some Kawasaki Guru's out there Would anyone know if a ZX7R ZX7RR 1996- 2003 P1 - P7 Quick action throttle would fit a ZX6R 1998 Ninja G1? Thanks! Link to comment Share on other sites More sharing options...
lorenzo Posted October 19, 2010 Report Share Posted October 19, 2010 What I do know is that a quick action throttle for a zx7r is the same as a normal throttle on a zx10r, which can be had pretty cheaply. Link to comment Share on other sites More sharing options...
LLCOOLJ Posted October 19, 2010 Author Report Share Posted October 19, 2010 What I do know is that a quick action throttle for a zx7r is the same as a normal throttle on a zx10r, which can be had pretty cheaply. Thanks! But i did some forum searching and it looks like it won't fit the ZX6R G1, bummer! Link to comment Share on other sites More sharing options...
gurninman Posted October 20, 2010 Report Share Posted October 20, 2010 well....... a G1 ZX6 has the same throttle tube as a ZX9 C2 and the assembly also appears to be the same as the ZX7-R A zx10r throttle tube will fit a ZX9 C2, and makes it into a quick action throttle, so I reckon you should be ok - you'll probably have to adjust the throttle cables a wee bit. Check the fiche on ronayers.com for part numbers... Link to comment Share on other sites More sharing options...
LLCOOLJ Posted October 20, 2010 Author Report Share Posted October 20, 2010 well....... a G1 ZX6 has the same throttle tube as a ZX9 C2 and the assembly also appears to be the same as the ZX7-R A zx10r throttle tube will fit a ZX9 C2, and makes it into a quick action throttle, so I reckon you should be ok - you'll probably have to adjust the throttle cables a wee bit. Check the fiche on ronayers.com for part numbers... Thanks fot that ! Will deffo check out tha part numbers :-) Do you know which version of the ZX10R? Link to comment Share on other sites More sharing options...
LLCOOLJ Posted October 20, 2010 Author Report Share Posted October 20, 2010 Thanks fot that ! Will deffo check out tha part numbers :-) Do you know which version of the ZX10R? Thanks for the link that really helped! Here is what i found: Throttle Tube Throttle Housing / Cable ZX6R G1 46019 (46019 - 1095) 32099 (32099 - 1193) ZX7R ZX750 P3 46019 (46019 - 1077) PART CODE N/A ZX9R ZX900 - C1 46019 (46019 - 1095) 32099 (32099 - 1193) ZX10R - ZX1000 - C1 46019 (46019 - 0001) 32099 (32099 - 1193) ZX10R - ZX1000 - C2 46019 (46019 - 0001) 32099 (32099 - 1193) ZX10R - ZX1000D6F 46019 (46019 - 0001) 32099 (32099 - 1193) ZX10R - ZX1000D7F 46019 (46019 - 0001) 32099 (32099 - 1193) Due to the ZX7R Throttle Housing part no. N/A, it's hard to tell if it fit. But the ZX10R will fit as it uses the same Throttle Housing/Cable, so i'm on a hunt for one :-) Thanks for the help! Link to comment Share on other sites More sharing options...
gurninman Posted October 20, 2010 Report Share Posted October 20, 2010 Thanks for the link that really helped! Here is what i found: Throttle Tube Throttle Housing / Cable ZX6R G1 46019 (46019 - 1095) 32099 (32099 - 1193) ZX7R ZX750 P3 46019 (46019 - 1077) PART CODE N/A ZX9R ZX900 - C1 46019 (46019 - 1095) 32099 (32099 - 1193) ZX10R - ZX1000 - C1 46019 (46019 - 0001) 32099 (32099 - 1193) ZX10R - ZX1000 - C2 46019 (46019 - 0001) 32099 (32099 - 1193) ZX10R - ZX1000D6F 46019 (46019 - 0001) 32099 (32099 - 1193) ZX10R - ZX1000D7F 46019 (46019 - 0001) 32099 (32099 - 1193) Due to the ZX7R Throttle Housing part no. N/A, it's hard to tell if it fit. But the ZX10R will fit as it uses the same Throttle Housing/Cable, so i'm on a hunt for one :-) Thanks for the help! There's usually a few on ebay - I picked one up for my ZX9 for about £4 Haven't fitted it yet, mind, because the cables need a bit of fiddling with and I've been too busy riding the bike to take bits off it. Link to comment Share on other sites More sharing options...
